Hi Guys,
Quick rundown of my current setup
Drag orientated Street car
Rb26/30
Gt35r .82 rear
3.5 exhaust
oem rb26 cams
600x300x76 justjap cooler
- made ~350rwkw @ low 20's psi i believe. More psi dosnt make any more power.
- Valve springs seem to be in ok condition.
- Intercooler believed to be holding setup back. rumours floating around that 3"+ outlets are a must on this type of setup. Thoughts?
- Car seems to suffer from some heat soak after a drive. What can i do to combat this?
- Inlet temps sit around the 50degrees but i could be off on this. i just remember my tuner saying it was a slightly high.
- 60mm atmo screamer pipe
- Highmount turbo - possible heat radiating from exhaust side, so i had almost everything i could lay my hands on ceramic coated. Considering Turbo bag or wraping, any thoughts or advice?
- Alot of heat radiating from under the motor, in the slight direction of the inlet side. Any ideas?
My conclusion is that a bigger, more efficient intercooler that isnt blocking off air to the radiator and among other things will solve a large majority of my cooling problems. So ive finally saved up enough money to buy a pretty decent intercooler. Having a look at Plazmamans range (and also having a chat to them) they have recommened their "1400hp Race Spec 100mm intercooler"
RACE SPEC GTR / S15 / WRX / VL
RACE SPEC - PRO SERIES . Universal fit intercooler designed for the big boys who want premium quality and performance . Plazmaman intercoolers are used world wide by all the leading race teams , and their valuable feed back and data sharing with us allows us to develop our range of intercoolers further so that we can offer you the customer the best possible result for your dollar - genuine 1400hp at only 8kgs total weight . Choice of 3.5 or 4 inch outlets ..... Plazmaman guarantees this to be the best performing intercooler of its type on the world market - Plazmaman pro series .
Dimensions: 600 x 300 x 100mm
Price: $1,845.00
I however thought to my self, 1400hp is pretty overkill for my application. My aim is to reach 400rwkw and possibly 450 on some better fuel. Taking this into consideration i had a look at their 800hp rated intercoolers.
600x300x3 inch tube and fin
ALL CHARGE AIR COOLERS ARE THE SAME?.........WRONG..The charge air cooler is by far the MOST important addition to any turbo vehicle. No matter how big your turbo , or boost level , if you can not flow and cool the charge air temp efficiently , your motor will experience detonation and not make maximum available real horsepower . NO WHAT IFS OR BUTS. Plazmaman has been at the forefront of power development in the sport compact industry for over 12 years , with customers smashing national records in all classes and forms of motor sport . Through this form of development , we have gained a wealth of knowledge in the construction of charge air coolers. Enter the ultra lightweight (5.5kgs) Plazmaman developed 600 x 300 FISION USA built unit .THESE INTERCOOLERS MAKE HORSEPOWER .All cores utilize the Plazmaman developed boundry layer air separation technique and are thermally dynamic. At Plazmaman you are treated like an individual - not a number . Each customer has a different vehicle setup , so it is only wise that we at Plazmaman carefully select a core with an internal and external construction to suit your power needs . Each individual intercooler is personally signed and numbered - OUR QUALITY GUARANTEE . End tanks are formed sheet alloy and are designed for maximum flow and even air distribution . Can be fitted with different style end tanks to suit different applications , and can be supplied in any finish specified .
Dimensions: Pro Series
Price: $875.00
If my setup is only able to make a decent 600hp,
Will a 800hp intercooler do the same job as a 1400hp intercooler? Or will the 1400hp be even better and offer more rewards?
How does having larger outlets affect things? going larger surely means more lag? Any thoughts or ideas on what would be ideal?
Really appreciate the help guys, i believe alot of people out there may have similar issues and it would be great to get some concrete resolutions.
  • Replies 52
If there is a pressure drop turn the boost up more. lol
haha, if only everything was solved by adding more boost =[
ive been surfing the vlcalai forums for a bit and the genral opinion is that ebay stuff will work and do its job, but the highend plazmaman stuff do the job alot more efficiently. im just thinking about the extra $800 id be left with and what i can get by buying ebay stuff. its temping but really confused as to if it really will solve my problems :(
what turbo and boost were you running to make 465rwkw?
jap_muscle, have you by any chance measured the pressure drop across the intercooler?? just curious as i have pretty much exactly the same setup, and im trying to squeeze every last hp i can out of the gt35r, been contemplating the upgrade to a 100mm cooler for a while
Jarrod
I had a China spec 600x300x76 core when i was making 430rwkw with only a 2psi drop at 26.5psi.
Now have a 600x300x100 with 3inch ends. Should handle the extra air.
They are both tube and fin cores.
GT35R also.
Jarrod
im in the exact same boat as you mate. ive been told to upgrade to a t04z or to a 1.06 but i want to get as much as i can out of the current setup before anything else. I havnt had a chance to do a pressure test but have something booked in on wed. will keep this thread updated. How much power did you make on your setup jarrod?
you could always get the 100mm cooler for extra flow.. and spend the 800$ left over on a water methanol injection kit, which will most likely help you alot more than any intercooler upgrade.
youve got a point here but i feel that it may somewhat overcomplicate things. Id just like to get the basics right first if you know what i mean.
GT35R also.
ive been a bit slack in following your build buddy. Hate to be noisy but could you help a fellow gt35r user in breaking into the 400kw?
how big is your exhaust?
what manifold you using?
i remember you wanting to play with the gt35x turbos. is it s standard 35r you used with a .82 when you made the 430kw?
were you running e85 on that?
any head work? cams?
really appreciate your help man. im pulling my hair out about why my build is a little lacking :thanks:
Edited by Jap_Muscle
Jarrod
Garrett T51r 1.05 rear and 24psi thru a C4 auto. Didnt get to run anymore boost as we were getting wheelspin on the dyno. Will be back on the rollers soon with E85 and more boost
Edited by WHITER33GTS-T
Probably. Still have the 150hp nos shot to add in for midrange. :thumbsup:
Last time I was running almost new 245/17s tyres but will run my hard worn out 18s next time. And will add a few extra straps to help hold it tight
I dont know why everyone thinks they can real off 400rwkw with a 35r on pump even with a 1.06 rear its a stretch - well it is on a proper reading dyno anyway. I would be looking at you exh back pressure before going any further.
Edited by rob82
i used to ask this quesiton alot, but there are a dozen people who have made it happen. Although talking about it is far different from actually making it happen, theres no denying that my setup is suffering from a power shortage somewhere. I guess ill find out sooner or later if its possible
i never got to make much power, i had the worse luck on the dyno, my car would run fine for months but play up on the dyno.
I made 420 hp on 16 psi low timing, moved it up to 21psi and it made 440hp at 4900 rpm with still low timing, but the run had to be cut short because the car started leaning out, that run looked like it was heading towards 460-470 easily without any timing added, we thought it should make 500hp easy and the tuner sent me home to work out the fuel issue, which after alot of head scratching i found that the alternator nut had worked itself loose.
After that i had some bad luck and broke my oil pump on the limiter, so im currently rebuilding trying to get everything right for the next attempt, my goals 400rwkw with all the extra money spent now, as well as the added poncams and methanol injection, which hopefully is enough hp for quarter mile time i want to run. Only question mark left in the car is this cheap intercooler kit i bought on ebay for like 270$ when i first got the car
Anyone know if these 100mm core coolers will swap directly with a 76mm 3"inlet n outlet styled intercooler?
Jarrod
It should swap over, cooler pipes might be a little tighter to get on.
Ive had dramas on the dyno too. 25/30 had a head rattle as it wasnt setup correct and a 26/30 that had oil cooler lines setup wrong resulting in a bent crank.
If you want more power buy my turbo setup. :whistling:
laggy with the t51r? how much power are you making at 100kmph/4000rpm?
ive also had a massive headache with controlling boost. went from a 38mm gate to a 33 and then eventually to a 60mm gate ive currently got. took a good few months to sort that out =[
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
