Hey, name's Essa (Zeus) ... Just recently bought a, used, gtr r34... first car bought using my own money cool.gif
was searching google.gif trying to find upgrades and some tutorials and came across this site. love the site, use it to read up on stuff while bored in lectures (attending Flinders, Adelaide) =P
https://www.sau.com.au/forums/topic/361381-hiya/
hmm, I'm a newb.
since gtr's are twin turbos then mine would be a none twin turbo r34 :P lol i dont know the guy's ad said it was an r34 :P no wonder it was cheap.
anyway, I still have a lot to learn from this forum and about skylines...
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768517
Welcome. Both GTR and GTT are R34... Its kinda like any other manufacturers, you've got the BMW 3 series but the 3 series' broken down into a few other variants (e.g. 318 and 335).
Even though to the untrained eyes the GTT and GTR might look the same but they're not. Both internally and externally. It'll take you a little while to be able to tell the difference between all GTRs and GTT/GTST.
I hope you're not ripped off thinking its a GTR.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768605
I bought this car because it was a skyline ;p Nothing more nothing less, the reason I said a "GTR" because it had the emblem ... I don't have much info about them, as I said "newb".
Thanks for clearing that up... So what would a non turbo be called? GT r34? Because mine certainly doesn't have a turbo and the guy definatley said it was an r34.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768720
Lol srsly, that makes sense since I couldn't find an r34 that looked like mine ;p
The guy must have typed it wrong then, r34. So would $5k be a rip off price for it? It had an odo reading of approx 155k when I bought it.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768837
Welcome.
Not a bad looking 33.
Things you should looking at doing to your skyline ASAP
  • Replace all fluids (engine oil, coolant, gearbox oil, diff oil etc)
  • Replace oil filter, fuel filter and air filter
  • replace spark plugs
  • Check for indications of 100000km service (i.e. timing belt has been replaced)
Replacment fluid types etc can be found in the general mainatence section or use the seach function and see where it takes you.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768977
Yup already did some of that. I don't trust previous owners unless a logbook is shown. Which this car didn't have. Did the full fluid replacement and replaced timing belt. But still need to do the filter replacements and spark plugs.
Will fix those sometime this week :)
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5769045
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
