Hey, name's Essa (Zeus) ... Just recently bought a, used, gtr r34... first car bought using my own money cool.gif
was searching google.gif trying to find upgrades and some tutorials and came across this site. love the site, use it to read up on stuff while bored in lectures (attending Flinders, Adelaide) =P
https://www.sau.com.au/forums/topic/361381-hiya/
hmm, I'm a newb.
since gtr's are twin turbos then mine would be a none twin turbo r34 :P lol i dont know the guy's ad said it was an r34 :P no wonder it was cheap.
anyway, I still have a lot to learn from this forum and about skylines...
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768517
Welcome. Both GTR and GTT are R34... Its kinda like any other manufacturers, you've got the BMW 3 series but the 3 series' broken down into a few other variants (e.g. 318 and 335).
Even though to the untrained eyes the GTT and GTR might look the same but they're not. Both internally and externally. It'll take you a little while to be able to tell the difference between all GTRs and GTT/GTST.
I hope you're not ripped off thinking its a GTR.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768605
I bought this car because it was a skyline ;p Nothing more nothing less, the reason I said a "GTR" because it had the emblem ... I don't have much info about them, as I said "newb".
Thanks for clearing that up... So what would a non turbo be called? GT r34? Because mine certainly doesn't have a turbo and the guy definatley said it was an r34.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768720
Lol srsly, that makes sense since I couldn't find an r34 that looked like mine ;p
The guy must have typed it wrong then, r34. So would $5k be a rip off price for it? It had an odo reading of approx 155k when I bought it.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768837
Welcome.
Not a bad looking 33.
Things you should looking at doing to your skyline ASAP
  • Replace all fluids (engine oil, coolant, gearbox oil, diff oil etc)
  • Replace oil filter, fuel filter and air filter
  • replace spark plugs
  • Check for indications of 100000km service (i.e. timing belt has been replaced)
Replacment fluid types etc can be found in the general mainatence section or use the seach function and see where it takes you.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768977
Yup already did some of that. I don't trust previous owners unless a logbook is shown. Which this car didn't have. Did the full fluid replacement and replaced timing belt. But still need to do the filter replacements and spark plugs.
Will fix those sometime this week :)
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5769045
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
