Hey all Im over drift and want to empty my shed so here is a list of all the goodies you can get your hands on.
I am located in Whyalla SA and will post almost anything anywhere in AUS
· Garret GT 30/40R .63 exhaust housing T3 flange $1200
· High flow RB25det turbo (GT2871R core) $800
· Microtech LT12s, RB25det plug & play adapter, hand controller, X6 igniter & 6 bosch coils $1500
· New Kazz 2 way lsd still in the box for S14, R32, R33 $800
· Used 2 way lsd in R33 diff housing $600
· R33 skyline no motor or gearbox rolling shell $1500
· RB25det race motor, built by lewis engins, race prepped block, blueprinted and balanced internals, Tomei oil pump, New RB26 crank, Scat forged rods, JE forged pistons, gapless rings, race ported head, full reco head, Tomei valve springs, hi energy sump, adjustable camgear, Extreeme light weight flywheel & 1600 kg puck clutch. This engine has been buit to put out over 350rwkw all day $6000
· RB25det gearbox $700
· R33 manual conversion, pedal box, clutch master & slave cylinders and lines, tail shaft, gearbox crossmember, gear boot surround $500
· R33 pumped metal front gards all metal big flare suit drift car $200
· Surge tank, Bosch 044 pump, bracket & speed flow fittings $300
· New 650cc top feed injectors, fuel rail, speedflow suit RB25det $550
· Haltech interceptor platinum suit any car $500
· Whiteline swaybars, pillow ball front linkages $350
· R33 3" Cat back exhaust with cannon $200
· R31 3" custom cat back exhaust with cannon $200
· Heaps of other skyline and performance parts, just txt or pm me with what your after
more pics coming soon or ask for specific items
Open to all serious offers
Shaun 0412 445 360
What brand is the used lsd and will you seperate the pillow ball mounts off the swaybars?
May consider parting the pillow balls from sway bars, what are you offering?
As for the diff it has no makings on it, then again nither does my new Kazz 2way :blink:
Hi there the 25 box is in good working condition, but yes has very worn synchros so if you dont drive it right it will grind the gear a lil into 4th mainly.
Yes I can get a quote for you to ship it to nsw at you expense.
My honest recomendation is that you put a new set of synchros through it and it will be good as gold
And yes it's definately a turbo box it's from my gtst
what is the rail that comes with injectors? pics?
Il get a pic of the rail today
Its just one of those ebay purple hks imitations comes with all fittings and injector reducers, speed flow fittings -8.
It will fit a forward facing manifold, I tried fitting it too a stock manifold and it didnt fit.
what mm are the swaybars? and are they adjustable?
also keen on the kaaz 2 way, do you have receipts for it? diff looks good but box looks ancient lol
also keen on any other r33 suspension/drift parts you may have.
pm me champ.
cheers
Adrian 0435 430 440
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
