And besides there is too much "thats awesome bro" comments on this forum in general...I give my honest opinion about everything...because I feel that if you put yourself out in the public like this forum you should expect some less than "omg you car is da bestttsset thing evor"
Otherwise we would have a forum full of arrogant dicks who think they are better than anyone else
If you have a search around and look at the EGO's of some GTR owners on here...and EVERY R35 owner on here all think they are top dog and cant handle people like me saying I dont like the R35
Hell I drive a Soarer...Im used to people saying what a piece of shit...untill they go go for a drive in one and realise that it doesnt have rattles like a millionaires baby It wont spin a bearing first time to take a corner quick etc
  • 3 months later...
hey guys this is my first topic lol
iv just brought a 2003 v35 gt350 coupe skyline
im a p plater and as i no i can put a turbo on it due to the law
i was just wondering if anyone could help me get the the most kWh i can get
out of the car until i can turbo
at the moment its around 206kWh stock
thanks
You could essentially look @ either the v35 section of the forum / look up g35driver..
Most common mods which occur first are
Exhaust + HFC / Test pipes (some say replacing the stock cats with HFCs / Test pipes is better than going exhaust + stock pipes. each to their own really lol)
Ztube + pod / panel filter (CAI)
5/16 plenum spacer
that should give you enough without killing yourself.
http://www.gtmotorsports.com/product.php?productid=16620&cat=473&page=1
/thread
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
