Fresh RB25 for sale built to same spec as NYTSKY's 430rwkw engine by Red R Racing
Acid dipped, crack tested, bored and strainer plate honed block
crack tested, cross drilled and grub screwed crankshaft
resized, honed and cryo treated RB26 conrods with ARP bolts fitted
CP 86.5mm forged piston kit with custom Red R ring package
ACL race series engine bearings
Nissan N1 oil pump and water pump
Gates timing belt kit with pulleys
cometic 1.2mm head gasket
fully reco'd cylinder head
HKS 256/264 camshafts
OS giken exhaust cam gear
HKS 850cc injectors
Twin scroll stainless manifold
50mm external gate
plazmaman inlet manifold
80mm throttle body
engine is only missing a turbo as im using the t04z twin scroll on my 30/26 engine.
it comes with an option of a Red R 8.5 litre sump fitted
this combo is a proven performer built by one of the best RB builders in aust.
$8900 or $9500 with race sump
https://www.sau.com.au/forums/topic/362039-nytsky-spec-built-rb25/
Supa Steve,
Can you ask your mate, Paul, to either call me and/or send me my oil pump please. He seems to be uncontactable.
you may need to leave a message if you cant get hold of him NX. Ive got to call them tommorrow to arrange an inspection of the engine for a buyer so ill let Paul know.
PM's replied to.
to those pm'ing about warranty, Paul stands by his work and is prepared to provide start-up warranty as well as advice on run-in procedure etc.
his after sales service is excellent and looks after customers long after engine is installed running and tuned.
PM's replied to.
Mate,
Paul is well aware of the situation (and I have spoken/sms'd/left messages to him many, many times about it) and I am sure he knows what must be done. Perhaps you could quietly remind him again when you see/speak to him next.
Thank you.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
