Hey mate I'm not in the Sydney area I'm in Albury and have a red 1996 R33 SII GTS that I have been considering selling if I can find a good GTS-T to replace it with. It has 81000km on the clock. $10500 Ono
Give me a text on 0447088100 and I'll send you pics and other information about the car if you are interested
Cheers, Kerrod
https://www.sau.com.au/forums/topic/362198-wtb-na-r33r34/#findComment-5781954
Hey mate
Have one for sale in newy... Nice and cheap... Check out http://www.skylinesaustralia.com/forums/topic/361346-1993-r33-gts-non-turbo-automatic/page__pid__5781922#entry5781922
Cheers scotty
Wanting to buy a non turbo R33 or R34, preferably in the Sydney region but any good offers will not be looked over.
Any help will be appreciated
Cheers
https://www.sau.com.au/forums/topic/362198-wtb-na-r33r34/#findComment-5782367
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
