For Sale
LS1 WH Caprice
Full Dark grey leather, good condition for age, no rips.
Electric sun roof (Slides and rises)
V8 aprox 205,000km (NO RATTLES TICKS OR KNOCKS, WELCOME COLD START INSPECTION IF REQUESTED)
Trans great condition very good firm shifts no slip
White over silver, good condition, chrome trim grille door handles etc.
20 inch spokey style wheels (Not In Pics) (New tyres less than 300km old)
16 inch stock caprice wheels (New tyres less than 500km old)
Can come with near new pedders super super low springs and near new front struts
New radio antenna (electric)
New power steer pump as was leaking
New Nolathane castor rod bushes
New Oil & filter less than 500km ago
New LHF window reg
New Handbrake button
Has had new radiator, and PCV lines etc replaced at some stage.
Brake pads are still @ 90%, Rotors recently machined.
Selling the car as my intersets have changed, have fixed a lot of problems with the car, its very comfortable, car has recently gone through major inspection by TSA As was defected for being too low, the car had super low king springs in the rear and low springs in the front when i got it. It still has legal king springs in the front and standards in the rear, however can come with pedders springs etc as mentioned above.
Car still has 'luxury' caprice badge sticking up off bonnet, un broken.
nice car, drives well.
$12500 ONO
MAY swap for GOOD import or MANUAL LS1 and cash your way if needed,
Located BAROSSA SA, Can meet.
Please call Lee on 0447910940, call or SMS. as i do not come on here often.
thanks.
https://www.sau.com.au/forums/topic/362338-fs-sa-wh-caprice/
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
