hey all,
I have my 1990 HCR32 4 door for sale. it has 205,xxx klms on the shell, I have only owned it for about 3 months now.. I'm selling to fund my next japan trip and to fund another project.
anyway, here is a list of mods.
- RB20det rebuilt at 110, 000 kms
- Gearbox rebuild at 161,000 kms
- Dr drift Remapped ECU
- Aftermarket roller bearing turbo, 440 hp rating
- Turbosmart bleed valve boost T
- Adjustable HKS cam gears
- Splitfire coils
- return flow Front mount intercooler
- 3 inch custom turbo back exhaust with highflow cat and Varex muffler
- New exhaust manifold studs and gasket
- Cusco oil catch can
- Walbro Fuel pump
- Excedy heavy duty cushion button clutch
- Cusco 2 way mechanical diff
- RBA slotted discs all round
- Front Project mu street pads, Rear Bendex ultimate
- Cusco brake master cylinder stopper
- jap spec Tien super street Coilovers
- Noltec Subframe bushes
- Noltec Sway bar bushes
- Gtr rear sway bar
- Front and rear strut braces
- Cusco adjustable castor arms
- Cusco upper front (camber) suspension arms
- Hicas lock bar
- Varex Muffler
- Weds Farmas rims 17 x 8jj fronts 17 x 9jj rears (rear wheels hand polished by me. look pretty awesome)
- 25mm bolt on spacers front and 8mm slip on spacers rear.
- HID Headlights ( projector/low beam)
- steering rack spacers
Interior
- Nardi wheel with Sparco quick release boss kit
- Blitz boost gauge
- Apexi turbo timer
- GTR Seats
Personally I'd love to keep this car, In the 3 months i've owned the car, I've changed all the gaskets on the head (bar the head gasket), serviced it, flushed all the fluids and replaced them and a few other bits and pieces..the RWC only recently ran out but is fine to pass another one! the car runs perfectly, gearbox has no crunches or grinds, diff is quiet, perfectly streetable car. my intentions were to build a 25/30 for it but I have another project in mind now.. the car makes 194rwkw at 1bar on Dr drifts dyno with Injectors being the limiting factor.
only issue with the car is the drivers side front qtr is rippled due to the previous owner having the car too low and the tires pulled the guard in.
sold with NO RWC (will pass one easily through my mechanic just needs to be raised and put the airbox back on) but will have a couple months reg. possibly 6/12 months pending sale price.
any questions, don't hesitate to call Leigh on 0418-221-075.
$9000 negotiable. throw me some offers!
https://www.sau.com.au/forums/topic/362503-r32-4-door/
  • 7 months later...
I'm looking unto selling this now but has had a fair bit done since I bought it!
I've replaced clutch master/slave, serviced, fixed leake's, fitted new air filter, fitted gtr 444cc injectors, removed the chip and had a nistune fitted and tuned to 19.8psi via a Eboost street boost controller,now it has on dmdtuning's dyno 240rwkw! I've also got a guard that still needs painting to fix the guard on drivers front, the car has had new rear breaks done, I've changed the wheels to sparco racing 5 spoke wheels 17x8 17x9, changed boost gauge to turbosmart psi, fitted a momo steering wheel, new black floor mats worth $$, so all in all I paid 9000 and I've spent another 4000ish so I'm looking to sell for around 11000ono
Edited by Slow4door
https://www.sau.com.au/forums/topic/362503-r32-4-door/#findComment-6157384
  • 4 weeks later...
  • 4 weeks later...
  • 2 months later...
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
