Hi :action-smiley-069: I'm Timothy but call me Tim or Timi.
I own an R33 with a RB25DET in a GTS shell :ninja: and have owned it personally for almost 3 months
It was a great find for me since its registered as n/a n im still a kid on L plates people just assume its not turbo because of the 4 stub hubs/wheels so its all good.
The Skyline is still a work in progress but has had a little done to it like: exedy button clutch, forged JUN pistons, Z32 afm, APEX-i power intake pod filter, larger radiator, Blitz LM fmic, Blitz dual solenoid boost controller, Nistune piggyback chip, decat exhaust, adjustable coilovers (not 100% sure on brand, previous owner said KONI but i think there only for GTR?), screamer pipe, GReddy RS dump valve (to be fitted; need adaptor), cold air intake, APEX-i sway bars and strut bars, removed HICAS, Nismo lsd.
Heaps of cosmetics too but not really intro-worthy :D
I'd like to do heaps more to it like ecu remapping, BEE*R rev limiter, 3.5inch exhaust with twin cannons, SARD 1000cc injectors, twin bosch 044 fuel pumps, garrett t04z bb tu rbo mounted on 6 stem turbo pipe (exhaust manifold), GReddy intake manfold, GReddy top feed fuel rail, Tomei poncams etc.:turned: Not in hurry though, just want it to be completed before my P's (18yo)
Not hard to notice my car round Victoria because its has 17" Advanti Medusas on her (ew..should be on a Camry :down: but i wana spend money on performance stuff first) and Nismo "Graphics" on the doors :wacko:
But like I said: its still a work in progress :cool:
:thanks: TY for reading n i hope to learn more on sau
Tim.
BTW! how do you get those litte pics of your car under your comments/posts? eg: VSPECT has little grey R33 GTR like his under his posts :banana: and GTS-T_Sedan has little gold EVO 7..there mad as!!! :worship:
https://www.sau.com.au/forums/topic/362566-my-sau-n00b-intro-from-vic/
Welcome Tim!
You certainly have more than a few bit's and piece's done to your car.
May i say, please don't forget at some point to put bigger brakes on it... this may mean a 5 stud conversion however.
Welcome again,
Shannon
Welcome... It's great to have grand plans...
However perhaps don't go out and build a 440rwkw / $35,000+ build right away, especially not with a N/A shell at least anyway.
I kid you not when I say it will kill you :)
Also to note, 3 points as soon as the Police pop the bonnet, something to be mindful of given it's turbo (and yes, the Police most certainly can tell just by looking at it).
Big thanks for the warm welcome so far :cheers:
I didn't want my intro to be an massive drain, just to keep it user friendly I just wrote the power wise upgrades I'd like to do :D
Bigger brakes are a must and so is a cage and other reinforcements since its going to be seeing laps and 1/4 miles (But not till I have heaps more driving expierience :laugh:) Also seats (incl. harnesses) are a required too. Already has strut/stabilizer/sway bars. Going to also do basic weight reductions and replace things with carbon fibre too.
Although I'm on my L's its not used and will never be used as a daily or in wet weather, its purely a weekender because during the week I got my mum's vx commo :teehee: lol petrol isnt cheap so commo is on gas. Once im on P's my dad will nurture the Skyline and I'll drive his Merc as well as Ninja 250 :ninja:
BTW power wise, aiming for figures around 280-300rwkw. Anything over is bonus but keeping it under 320rwkw. Shes runnin 14psi atm but want to replace turbo first (Shattering ceremic turbo blades sound really frightening :unsure: )
The build is going to last over a period of 18-24 months so there is plenty of time for learning as well as progression.
Exteriorly the car looks pretty basic apart from graphics lol, but as R31Nismoid said, its obvious is a turbo under the bonnet + massive fmic literally gives it away but side on eg: at traffic lights, all you see are 4 stud rims and blue "GT" emblem on side but it flutters/"Doses" like a mofo which also kinda gives it away :wacko:
Thnx heaps,
Tim
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
