1990 Model R32 GTR Skyline (Gun Metal Grey)
RB26 DETT Fresh Engine Installed. (106k’s)
Fitted with:
S.A.R.D. injectors, Fuel Pressure Regulator, Fuel Rail Adaptor Plate
Bosh Race Spec Fuel Pump.
Brand New Water Pump (23/4/11)
Red Anodised Cam Gears (hidden under standard timing cover to avoid defects)
R34 GTR Turbos
1.5 Way Cusco Diff
Turbo Back - 3in Exhaust with Hi Flow Cat
Rear Main, Cam Seals, Crank Seals, all gaskets brand new (23/4/11)
Apexi Power FC (with hand controller)
Turbo Timer
Z32 Air Flow meters
New Oxygen Sensor
Blitz Bleed Valve Boost Controller
Boost Gauge
Twin Trust Air Filters
Adjustable Damper Front Struts
Adjustable Front Camber/Caster Tie Rods
Lowered Springs
New Factory Drilled Rotors and Bendix Pads
New Bob Jane Xennon Front and Rear Tyres
New Oils, Plugs, Coolant, Turbo Gaskets
New Gear Boot (Leather) and handbrake Boot (Leather)
Momo Sports Steering Wheel
The car is getting tuned tomorrow 02/05/11 with somewhere near 300 KW (420Bhp) expected
at the wheels on 16lb boost. That means nearly 500BHP at the flywheel.
That means, very quick (in layman’s terms) The old motor had 392 RWHP @16lb on R32 Turbos.
The Gun Metal Grey paint and body are immaculate and will be fully appreciated upon inspection.
The interior is stock and has recently been cleaned by qualified upholstery cleaner.
The car is built for total performance on street or track although never seeing a race track.
The GTR is fitted with the standard GTR 16in light weight rims which are in immaculate cond.
Owned by mature owner. Registered to 21st June 2011. Can put 12 months rego on.
The car has had nearly $20K spent on it to get it to where it is. I have just spent a $1000 on
a full service and the fresh tune. The car has been owned by 3 mature people since it was imported.
The quality of the car and the subtle improvements reflect the senibility of it owners.
Everyone that sees the car or stops me at the service station to have a look all comment on how clean the car is.
Its a nice feeling to know you own a quality piece of motoring history.
Red Book says the GTR’S are valued between $13,500 – $16,600 (in standard trim)
I am advertising my second wife for $23,000 with a little (meaning a little) room for negotiating. Please don’t
ring with 16 or 17 grand to spend. You will be wasting both yours and my time.
I’m selling the car for personal reasons and I am NOT in anyway interested in swapping for someone elses pride and joy.
I will post the exact RWKW output tomorrow after it is tuned and some photos (when it stops raining)
Any question or for pictures can be directed to me at [email protected] or you can give me a ring.
0405-321-356. The car is in Western Sydney (near Penrith).
Thanks for viewing.
Trevor
GTR PIC1.doc
https://www.sau.com.au/forums/topic/362672-fs-r32-gtr-gun-metal-grey/
On Monday 2 May 2011 my GTR was tuned by Chris and Rob at Incar Racing, Wetherill Park. What a good job they did.
The car is running 17lb of boost and clocked up 282Rwkw. The boys said that they could have run it up a bit harder but
the car is a streeter and now has more than enough power.
PICS to be posted of car by Friday.
Cheers
PLEASE NOTE, I HAVE TAKEN ALL THE PICS BUT THEY WONT LOAD UP DUE TO BEING JUST BIGGER THAN 2MB. (2.2) IF YOU WANT THEM PLEASE JUST EMAIL ME AND I WILL SEND THEM TO YOU STRAIGHT AWAY.
SORRY FOR ANY INCONVENIENCE CAUSED... TREVOR
RB26 DETT Fresh Engine Installed. (106k's)
Fitted with:
R34 GTR Turbos
1.5 Way Cusco Diff
Turbo Timer
Z32 Air Flow meters
New Oxygen Sensor
Boost Gauge
Lowered Springs
That means, very quick (in layman's terms) The old motor had 392 RWHP @16lb on R32 Turbos.
Red Book says the GTR'S are valued between $13,500 – $16,600 (in standard trim)
I am advertising my second wife for $23,000 with a little (meaning a little) room for negotiating. Please don't
I'm selling the car for personal reasons and I am NOT in anyway interested in swapping for someone elses pride and joy.
Thanks for viewing.
Trevor
Mate,
If you tell me how, I will. The pics are on gumtree and ebay... I am crap with computers and thats why I had to put it on the other sites..
Or call me or sms me your email and I'll send them directly to you mate...
Cheers
Trevor
Fitted with:
R34 GTR Turbos
1.5 Way Cusco Diff
Turbo Timer
Z32 Air Flow meters
New Oxygen Sensor
Boost Gauge
Lowered Springs
New Bob Jane Xennon Front Tyres
The interior is stock and very clean for it age.
a full service and the fresh tune. The quality of the car and the subtle improvements reflect the senibility of it owners.
Red Book says the GTR'S are valued between $13,500 $16,600 (in standard trim)
I am advertising my second wife for $19,500. Please don't ring with 16 or 17 grand to spend.
The car has been tuned and is pumping out a respectable 281.8kw at the rears on 17lb of boost.
email="[email protected] or you can give me a ring. 0405-321-356.
Thanks for viewing.
Trevor
Edited by Trevor R32
  • 1 month later...
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
