Hi all,
As title states, I have a GT2876r. 82. rear housing for sale.
-Internally gated.
-No shaft play.
-Perfect condition.
Made 250kw atw on a Liberty.
Better suited to an RB or SR engine.
After $1000 + postage
Located in Canberra and will ship at buyers expense.
pics up soon
Cheers
https://www.sau.com.au/forums/topic/363013-garrett-gt2876r/
Could you PM me some pics & any extra info you have?? T3 flange im guessing....could you also PM me best price for cash on delivery pick up if i make a special trip??
Cheers
https://www.sau.com.au/forums/topic/363013-garrett-gt2876r/#findComment-5805428
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
