Hi all,
I'm selling my 1989 R32 GTR which i have owned for a little over a year. It was previously owned by 'YAWN' (Melbourne). It has spent 90% of the time i have owned it in the shop with the engine stripped back and re made to what is listed below and what you see in the pictures. All engine gear is brand new with top quality parts.
I'm selling it due to other commitments including the purchase of a new car & boat - I'm not interested in swaping for anything, thanks.
As i dont care much for computers, i dont own one, so i'm writing this with the help from a mate.
125,000 Km’s on the clock – less than 5,000 on the new motor
All engine gear is brand new!!
· Tomei 2.8L Kit
· New R34 N1 Crank
· Tomei Pistons & Rods
· Jun oil pump (Billet)
· 9L extended sump
· ACL race serves main + big end bearings
· BAL rotating assembly
· Studs through out / ARP rod bolt
· Tomei pro cams
· Heavy duty springs (Valve)
· Ported head
· Adjustable cam gears
· Garret T042 Roller turbo
· Turbosmart 50mm gate (screamer)
· Exhaust manifold
· 3 Inch exhaust – Jazima
· Blitz BOV
· Exedy twin plate clutch / billet flywheel combo
· Dog box
· Apexi Power FC / Detro conversion
· Ray’s wheels
· Ohlins coilovers
· Brembo brakes
· Slotted rotters
· Dephi Gauges
· Momo steering wheel
· Nismo dash
· 4 Point harness
· Sony head unit
  • Bride bucket seat
  • Oil Catch can
  • Carbon Fibre hood
  • Front mount intercooler
There is probably a few more things not listed that i cant remember.
Car makes 400 KW ATW on 20 PSI – 98 Ron Fuel
Looking for $33,000 ONO
Car located on the north shore in Sydney.
Best to call to discuss.
Call me to come organise a time to come see the car -Damon 0406 819 511
Thanks.
post-65218-0-65662300-1304654530_thumb.jpgpost-65218-0-46415100-1304655270_thumb.jpgpost-65218-0-62442200-1304655276_thumb.jpgpost-65218-0-68495700-1304655286_thumb.jpgpost-65218-0-02039300-1304655292_thumb.jpgpost-65218-0-91007400-1304655300_thumb.jpgpost-65218-0-34868300-1304655307_thumb.jpgpost-65218-0-92617900-1304655313_thumb.jpgpost-65218-0-01307200-1304655320_thumb.jpgpost-65218-0-69830500-1304655326_thumb.jpgpost-65218-0-12556600-1304655333_thumb.jpgpost-65218-0-24236300-1304655341_thumb.jpg
https://www.sau.com.au/forums/topic/363317-1989-r32-gtr-400kw-atw/
Get Set:
2 oil pumps (N1) blew as they couldn't handle the power & the bearings seized to the crank, therfore the crank was replaced to the R34.
Dog box - straight cut gear set - syncro
Cams - Pro Cams.
If you want full specifications , You will have to give Tomei a call to retrieve off them as i dont have them.
Tony @ Boostech in Five Dock built and tuned the car.
Cheers!
Oh Dear Arab Skidder, "im confused on how does a r34 crank fit in a block now honned to 2.8ltrs?" Does anyone want to explain to this serial pest how wrong his comment is and why it makes him look like a uneducated twat? Hey AB, leave this thread alone, I think we can all make up our own minds about it.
:pirate:
update:
1000cc injectors - i believe they are siemans
Walbro internal pump - no surge tank
Unaware of the brand gear set sorry.
Car needs to go.
I will be putting it on carsales hopefully tomorrow to get it sold.
Thanks.
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
