  • Replies 116
RB25 Alternator $55 SOLD
RB25 Starter Motor $50 SOLD
R33 gtst sr1 radiator fan and hub SOLD
rb25det tailshaft SOLD
sniper scuffs SOLD
PRICE DROP ON MOST ITEMS
RB25det sump $40
R33 sr2 wing needs paint $40
GTR wing no end caps needs painting $200
R33 Air Conditioning Condenser gtst 1994 $40
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 climate control $40
R33 gtst fuse box and cover $20
R33 gtst sr1 brake booster and master cylinder $65
R33 gtst sr1 bonnet hinge set $15
R33 gtst overflow and washer bottle $25 for both
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $70
R33 gtst battery tray need painting $15
R33 manual gear shift boot/plate $20
R33 gts-t rb25det Genuine manual radiator in good working condition $45
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $55
R33 clutch master cylinder $30
R33 RB25 skyline power steering reservoir with lines $20
RB25det fuel rail $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $25
R33 Air Conditioner Compressor with lines as seen in pic $65
r33 gtst front door speaker pods $10
RB25det sr1 aac valve $50
pm me or 0435888239
Will post at buyers expense
r33 gtst sr1 carbon bonnet bought from autobarn paid $1300 a few years back only used on my car for a few months just been sitting in my shed. has a few light scratches $450
sniper scuffs SOLD
RB25det sump $40
r33 gtst sr1 carbon bonnet $450
fiberglass vent (uncut vent) $70
pm me or 0435888239
sniper scuffs SOLD
gtr drag intercooler SOLD
RB25det sump $35
R33 sr2 wing needs paint $35
R33 gtst battery tray need painting $10
RB25det sr1 aac valve $45
r33 gtst sr1 carbon bonnet $440
fiberglass vent (uncut vent) $60
pm me or 0435888239
sniper scuffs SOLD
RB25det sump $35
rb25 turbo 45v2 has a blown seal $60
pm me or 0435888239
sniper scuffs SOLD
r33 gtst front door speaker pods SOLD
RB25det sump $35
R33 gtst sr1 abs unit and bracket $70
R33 gtr intercooler (corrosion on bottom)$40
Rb25det sr1 flywheel $45
R33 gtst coupe sr1 door handle's $35
R31 sr3 grill $15
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$35
R33 gtst light garnish $30
R33 centre interior light plus other? $25
pm me or 0435888239
Dave
sniper scuffs SOLD
R33 gts-t radiator SOLD
RB25det sump $35
GTR wing no end caps needs painting $180
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $65
R31 sr3 grill $10
R33 sr1 eyelids(they need prep work before paint) $15
pm me or 0435888239
Dave
RB25det sump $35
R33 sr2 wing needs paint $30
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $60
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $50
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
R33 Air Conditioner Compressor with lines as seen in pic $60
RB25det sr1 aac valve $40
r33 gtst sr1 carbon bonnet $420
rb25 turbo 45v2 has a blown seal $50
R33 gtst sr1 abs unit and bracket $65
Rb25det sr1 flywheel $40
R31 sr3 grill $10
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$30
pm me or 0435888239
Dave
RB25det sump $35
R31 sr3 grill $10
R33 turbo oil drain pipe $10
pm me or 0435888239
Dave
RB25det sump $30
GTR wing no end caps needs painting $160
R33 Air Conditioning Condenser gtst 1994 $35
R33 gtst sr1 climate control $35
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $55
RB25 R33 GTST SR1 CAS CAM ANGLE SENSOR AND BRACKET $45
R33 Air Conditioner Compressor with lines as seen in pic $55
r33 gtst sr1 carbon bonnet $400
fiberglass vent (uncut vent) $55
R33 gtst sr1 abs unit and bracket $60
R33 gtr intercooler (corrosion on bottom)$35
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $90
r33 horns $10
r33 sr1 bonnet in primer has a few scratches and a small dint from sitting in the shed $120
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
catco high flow cat 2.5inch 325mm long $50
apex rb25 front pipe 2.5inch has a few dings $100
Nismo muffler 2.75mm inlet with 4.5inch tip $150 plus rear section that suits r33 free with muffler
pm me or 0435888239
Dave
PRICE DROP
RB25det sump $30
GTR wing no end caps needs painting $150
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50
R31 sr3 grill $10
r33 horns $10
apex rb25 front pipe 2.5inch has a few dings $90
Nismo muffler 2.75mm inlet with 4.5inch tip $140 plus rear section that suits r33 free with muffler
pm me or 0435888239
Dave
sniper scuffs SOLD
R33 gtst sr1 brake booster and master cylinder SOLD
R33 manual gear shift boot/plate SOLD
R33 sr1 eyelids SOLD PENDING PAYMENT
R33 gtr intercooler SOLD PENDING PAYMENT
PRICE DROP
RB25det sump $30
fiberglass vent (uncut vent) $50
R31 sr3 grill $10
r33 horns $10
apex rb25 front pipe 2.5inch has a few dings $80
pm me or 0435888239
Dave
sniper scuffs SOLD
PRICE DROP
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 20
R33 gtst sr1 electric driver side window switch and loom $60
R33 gtst sr1 passenger side electric window switch and loom $50
pm me or 0435888239
Dave
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
R33 gtst sr1 2door seat belts(not sure if its complete) $50
RB25 clear timming belt cover(never used)$70
pm me or 0435888239
Dave
PRICE DROP ON SOME ITEMS
RB25det sump $30
R31 sr3 grill $10
r33 horns $10
apex rb25 front pipe 2.5inch has a few dings $70
Nismo muffler 2.75mm inlet with 4.5inch tip $130 plus rear section that suits r33 free with muffler
R33 gtst window wiper set $ 15
R33 gtst sr1 electric driver side window switch and loom $50
R33 gtst sr1 passenger side electric window switch and loom $45
RB25 clear timming belt cover(never used)$60
pm me or 0435888239
Dave
RB25 clear timming belt cover SOLD PENDING PAYMENT
RB25det fuel rail SOLD PENDING PAYMENT
RB25det sump $30
R31 sr3 grill $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $80
r33 horns $10
pm me or 0435888239
Dave
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
