cruzin33 Posted October 1, 2011 Author Share Posted October 1, 2011 R33 Air Conditioning Condenser SOLD PENDING PAYMENT R33 rb25det charcol canister SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 climate control $35 R33 gtst sr1 bonnet hinge set $15 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor with lines as seen in pic $50 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running car but hade different plugs to myn) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6040420 Share on other sites More sharing options...
cruzin33 Posted October 2, 2011 Author Share Posted October 2, 2011 R33 Air Conditioning Condenser SOLD PENDING PAYMENT R33 rb25det charcol canister SOLD PENDING PAYMENT R33 gtst sr1 climate control SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor with lines as seen in pic $50 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running car but hade different plugs to myn) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6041438 Share on other sites More sharing options...
cruzin33 Posted October 5, 2011 Author Share Posted October 5, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor $40 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6046195 Share on other sites More sharing options...
cruzin33 Posted October 9, 2011 Author Share Posted October 9, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor $40 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6052479 Share on other sites More sharing options...
cruzin33 Posted October 9, 2011 Author Share Posted October 9, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor $40 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $170(was going to build a forged rb25 for my 31 but now need money for another project) ARP rb25 Exhaust Manifold Kit new never used $100 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6052601 Share on other sites More sharing options...
Trav1991 Posted October 10, 2011 Share Posted October 10, 2011 how much for 6 injectors and the turbo drain pipe and can u post to sa Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6053457 Share on other sites More sharing options...
cruzin33 Posted October 10, 2011 Author Share Posted October 10, 2011 pm sent Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6053884 Share on other sites More sharing options...
cruzin33 Posted October 13, 2011 Author Share Posted October 13, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor $40 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project) ARP rb25 Exhaust Manifold Kit new never used $100 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6060575 Share on other sites More sharing options...
cruzin33 Posted October 15, 2011 Author Share Posted October 15, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor $40 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project) ARP rb25 Exhaust Manifold Kit new never used $100 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6063433 Share on other sites More sharing options...
cruzin33 Posted October 17, 2011 Author Share Posted October 17, 2011 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor $40 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project) ARP rb25 Exhaust Manifold Kit new never used $100 I have r33 interiour parts, pm for what you after R33 bonnet in black primer has a small bend in lip $50( can get pic) pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6065337 Share on other sites More sharing options...
cruzin33 Posted October 18, 2011 Author Share Posted October 18, 2011 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 R33 Air Conditioner Compressor $40 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project) ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6067613 Share on other sites More sharing options...
cruzin33 Posted October 19, 2011 Author Share Posted October 19, 2011 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar with gtr pods both will need repair $50 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project) ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6068917 Share on other sites More sharing options...
cruzin33 Posted October 21, 2011 Author Share Posted October 21, 2011 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash, heater cores $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 gtst R/H drivers door glass $40 R33 gtst L/H drivers door glass $40 R33 rear window $70 R33 gtst front fenders rolled and liped $170 for both R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50 RB25det stock dump on black vht $20 R33 gtst rear bar, will need repair $25 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project) ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6073196 Share on other sites More sharing options...
cruzin33 Posted October 22, 2011 Author Share Posted October 22, 2011 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts(not sure if its complete) $50 R33 gtst sr1 air con units that sit behind the dash, heater cores $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $15 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 rear window $70 R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50 R33 gtst false rear wall $20 RB25det stock dump on black vht $20 R33 gtst rear bar, will need repair $25 r33 gtst sr1 power window motor regulator LHS $80 r33 gtst sr1 power window motor regulator RHS $80 R33 gtst rb25det hicas computer $60 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project) ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6074307 Share on other sites More sharing options...
cruzin33 Posted October 26, 2011 Author Share Posted October 26, 2011 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT r33 gtst sr1 power window motor regulator d/s $80 SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts complete $50 R33 gtst sr1 air con units that sit behind the dash, heater cores $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $10 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 rear window $70 R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40 R33 gtst false rear wall $20 RB25det stock dump on black vht $20 R33 gtst rear bar, will need small repair $25 r33 gtst sr1 power window motor regulator passenger side $80 R33 gtst rb25det hicas computer $50 ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150 ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Dave Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6080970 Share on other sites More sharing options...
cruzin33 Posted October 28, 2011 Author Share Posted October 28, 2011 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT ARP RB20 RB25 HEAD STUDS BOLTS KIT SOLD PENDING PAYMENT RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts complete $50 R33 gtst sr1 air con units that sit behind the dash, heater cores $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $10 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 rear window $70 R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40 R33 gtst false rear wall $20 RB25det stock dump on black vht $20 R33 gtst rear bar, will need small repair $25 r33 gtst sr1 power window motor regulator passenger side $80 R33 gtst rb25det hicas computer $50 ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20 Rb25det sr1 cas with bracket $50 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Dave Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6083724 Share on other sites More sharing options...
cruzin33 Posted October 29, 2011 Author Share Posted October 29, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts complete $50 R33 gtst sr1 air con units that sit behind the dash, heater cores $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $10 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 rear window $70 R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40 R33 gtst false rear wall $20 RB25det stock dump on black vht $20 R33 gtst rear bar, will need small repair $25 r33 gtst sr1 power window motor regulator passenger side $80 R33 gtst rb25det hicas computer $50 ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20 Rb25det sr1 cas with bracket $50 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Dave Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6084851 Share on other sites More sharing options...
cruzin33 Posted November 1, 2011 Author Share Posted November 1, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts complete $50 R33 gtst sr1 air con units that sit behind the dash, heater cores $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $10 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 rear window $70 R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40 R33 gtst false rear wall $20 RB25det stock dump on black vht $20 R33 gtst rear bar, will need small repair $25 r33 gtst sr1 power window motor regulator passenger side $70 R33 gtst rb25det hicas computer $50 ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20 Rb25det sr1 cas with bracket $50 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Dave Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6089568 Share on other sites More sharing options...
cruzin33 Posted November 4, 2011 Author Share Posted November 4, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts complete $50 R33 gtst sr1 air con units that sit behind the dash, heater cores $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $10 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 rear window $70 R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40 R33 gtst false rear wall $20 RB25det stock dump on black vht $20 R33 gtst rear bar, will need small repair $25 r33 gtst sr1 power window motor regulator passenger side $70 R33 gtst rb25det hicas computer $50 ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20 Rb25det sr1 cas with bracket $50 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Dave Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6095416 Share on other sites More sharing options...
cruzin33 Posted November 6, 2011 Author Share Posted November 6, 2011 RB25det sump $30 R33 sr2 wing needs paint $30 R33 gtst sr1 front wiper motor $30 R33 gtst sr1 rear wiper motor $35 R33 gtst sr1 bonnet hinge set $15 R33 RB25 skyline power steering reservoir with lines $20 RB25det sr1 aac valve $40 fiberglass vent (uncut vent) $50 R33 gtst sr1 abs unit and bracket $60 Rb25det sr1 flywheel $40 R33 gtst coupe sr1 door handle's $30 R31 sr3 grill $10 R31 sr3 bits lot $15 R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25 R33 gtst light garnish $30 R33 centre interior light plus other? $25 R33 turbo oil drain pipe $10 rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70 r33 horns $10 Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler RB hard oil turbo line $25 (not sure if its rb20 or rb25) RB hard water turbo line 1 $25 rb20 rb25? RB turbo hard water line 2 $25 rb20 rb25? R33 gtst window wiper set $ 15 R33 gtst sr1 passenger side electric window switch and loom $45 R33 gtst sr1 2door seat belts complete $50 R33 gtst sr1 air con units that sit behind the dash, heater cores $90 RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20 vr v6 commodore sedan fuel sender and pump(pulled from running) $40 r33 boot latch with plug $20 R33 boot and fuel lever $15 R31 1989 oz spec bonnet latch and lever $10 R33 a/c receiver,drier sensor $30 rb25det fuel modulator with bracket$25 R33 rear window $70 R33 stereo brackets $20 R33 sr1 dash trim(needs a clean and paint) $40 R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25 r33 sr1 bonnet in primer$100 has a small dent(can send pics) R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $40 R33 gtst false rear wall $20 RB25det stock dump on black vht $20 R33 gtst rear bar, will need small repair $25 r33 gtst sr1 power window motor regulator passenger side $70 R33 gtst rb25det hicas computer $50 ARP rb25 Exhaust Manifold Kit new never used $100 R33 bonnet in black primer has a small bend in lip $50( can get pic) R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $20 Rb25det sr1 cas with bracket $50 R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET $50 I have r33 interiour parts, pm for what you after pm me or sms 0435 888 239 Will post at buyers expense Dave Link to comment https://www.sau.com.au/forums/topic/364044-shed-clean-out/page/5/#findComment-6097512 Share on other sites More sharing options...
