  • Replies 61
what series rb26 is it because it looks like an rb25 to me ?
RB26 breather hoses are towards the rear of the cam covers and the covers have different curves on them. So I think you're right. Or its an RB26 with its cam covers swapped.
help, fwiw, I prefer pnuematic boost control too.
Guest INASNT
hmm true, didnt spot that.
Y would u swap cam covers???
Could this be part of power problem ? and that T-piece boost controller, they can only handle a certin amount of boost before they do what they want.
eg: it can only hold upto 14psi intill it canrt hold it any more and the boost will go all over the place ? that why i said turn the boost right down and see if it works any differnt.
at a guess its a 1.0 rear housing...
get a few places to look at it as a basic engine checkup and see if they all concur similar idead about your car... i know this is money but it will iron out most of the probs...
forget the t piece to although its not ideal the car still runs 22psi, agains boost controllers affect response and delevery. if the gauge is running from the plenum and it reads 22 psi then the bleeder is working in creating this boost... in responding we need to remember its not that he cant make boost its that the power figure for that boost reading isnt right which means its a ignition issue ie. the fuel isnt being lite, or a fueling issue theres not enough or theres to much fuel... look at this would be my advise to you get a better tuner someone who knows haltech, go to haltech.com.au or something and look up there distributers for your area im sure most of them are workshops with dynos use one of them to tune the vehicle. theres also a forum on the site you can ask whos the best in your area!!
Trust me it is an RB26 I will take a picture of the engine number if you like :) I did that for the exact same reason you guys were argueing. Open the bonnet it just looks like a 25 but it is really a 26. Before I blew my 25 however I did have a gtr plemun and throttle bodies fitted to the car so for those who have asked it can be done just need and adaptor plate made up. It made the throttle heaps more responsive on the 25, I think it was worth it you can get the right people to do the work. RNS11Z thanks for you're help mate I will give him a call today. Thanks for the help guys i will keep you posted on what is happening. Are most of you guys running power fc's and has anyone ripped out and old computer to put in a new had any problems.
Guest INASNT
sure u havent been jibbed by the guy that did the convertion??? You cant fit rb25 covers to the rb26, they dont sit on there properly.
I got a PFC and have had no problems with it.
Is anyone here making over 300KW with a halteck on board, if so did you have any tuning problems/sensor problems. What are you guys using computer wise to make good power.
i fink u r using the wrong computer for an rb26 motor...u need something that tunes through throttle position the e6k does not have this feature.... it will thus be running super rich on cruising and possisbly making it feel like a nugget to drive... the mictotech mtx12 or something like that tunes through throttle position or y not go for the e11 which i would recomend for a rb26 ..... hope this info can help.... call adam from JEM in sydney he can tell you what u need to know about haltechs (02) 96006567 correct me if im mistaken :wavey:
i know of a few skylines making over 300rwkw with a haltech
good point amu but this doesnt matter as it is not making power as opposed to not cruising nicely.... WOT is WOT if the computer knows that, which it does, then its tuning and so forth... help, go for your real problem as i have stated before your car isnt making numbers at 22psi... it makes 22psi so theres no turbo related problem the problem lies between where your boost gauge is plumed and the exhaust ports!!!!
Hi Help, I'd like to start with the wastegate, I have pretty good success using this formula to determine external wastegate sizes;
Airflow in lbs per minute = diameter of wastegate in mm X boost correction factor
So let's apply it to your car;
300 rwkw = 480 bhp
480 bhp = 44 lbs of airflow = 44 mm wastegate
Now if you want to run 19 psi, then that's the right size wastegate.
But we need to apply the boost correction....
My experience indicates that to get 300 rwkw out of a GT3040 you would need to run around 1.5 bar (22psi). So using the formula...
44 / 22 X 19 = 38 mm.
For those who haven't read the thread..............
http://www.skylinesaustralia.com/forums/sh...light=wastegate
So I would say that your wastegate is too big, what this means is it has to open and close more often, as it has too little exhaust flow when closed and too much exhaust flow when open. All this opening and closing of the wastegate affects the amount of exhaust flow though the turbine, this leads to fluctuations in the boost control. eg; I have seen a relatively low powered engine, with a very large wastegate, move up and down 0.3 bar in its boost as the boost control circuit struggles to keep up with this open, closed, open, closed requirement.
Moving on to one of my favourite subjects, the wastegate actuator spring rate. If you want to run 22 psi then you should have an 18'ish psi spring in the wastegate actuator. That way the boost controller only has to control the 4'ish psi. If you have say a 12 psi spring, then your boost controller (doesn't matter what type) is struggling to keep up with bypassing (or pulsing) the required amount of pressure (10 psi) to control the boost.
Summing up, I think you have 2 problems, the wastegate is too big and (most likely) you have too light a spring in the wastegate actuator. Consequently I am not at all surprised that you have boost control issues. The bypass style boost controller is probably not helping, but it isn't the cause of the problem.
So the very first thing I would do is make sure you have at least an 18 psi wastegate actuator spring. If not then get one, I reckon it will fix most your boost fluctuation problem.
Lastly, too big a wastegate, since it seems to run OK at low boost and makes good power there, that would confirm the calcs that the wastegate is too big. I would try the spring mod first and if it is still a problem then look at trying a smaller wastegate.
Hope that makes sense.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
