post-80841-0-82125200-1305247492_thumb.jpg Hi Guys. Got a few parts for sale.
ATR43G3 Turbo
Km: 3000km Or less (Basically new)
Technical: ATR43G3 Turbo .82 internally gated.
Condition: No shaft play (When bought was taken to Yavuz at UniGroup And he said the turbo felt great).
INCLUDING: stock exhaust mani AND a Stainless Steel Dump pipe.
Due to some personal issues i have been unable to install the turbo. I bought it off ( MBS206 ), Who is a NSW Executive. So if you have questions about the turbo's past just send him a PM hell vouche for the turbo :). As i said i havent even used it since getting it. The turbo itself is running a hypergear High pressure actuator rated at 14PSI. This type of turbo has been seen making 300RWKW+ if on E85 you could be looking at more.
PRICE: $850 ONO (NO LOW BLOWS)
TIEN SUSPENSION NR Suit R33 GTST series 1 or 2.
Ok guys Ive got these laying around i don't need them. There selling DIRT cheap because the rear passenger side has a minor leak easily fixed but i need them gone
PRICE: $250 FIRM
ALSO.
TRUST REAR BAR
Will Suit R33 GTST all Models. NEVER used got it with the car when bought as an extra. Still in original Gel.
PRICE: $200 FIRM
Pictures are below. All located in Sydney will post at buyers expense.
Contact: 0401200176 (msg me cause i work and ill call you back.) No clowns please,
Regards
Sid
are you goin to post the items ive texted but no reply can u send me the dump pipe asap then ill take the rest after that cheers
You haven't sent me any address details buddy. I cant send them via The post if you dont give me the address, Plus theres other people interested. If someone local grabs it before i can send it via post then great.. Im sorry mate but i work 8 30 to 5... And my boss wont let me have time off this week to just drop into the post office to send it. So if i was to send it i can only make it by saturday, so ive been flat out busy thats why you havent recieved a replay yesterday and today.
Sid
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
