1996 Honda Civic Coupe EJ8 (with em1 goodies) only done 138,000ish KMS
This car is a good daily. Never breaks down, it only have minor damage on the right frond fender side just a dent. Other than that its fine. very good to run. Only needs brake and minor service. Driver's side window needs little fixing .Im selling the car for financial reasons and i need an upgrade.
Mods:
B16a2 dohc VTEC engine
15' Japanese white rims (i dunno the brand)
Datsumi bullbar
Precision Vtec Controller
2.5" Exhaust
Mugen style Airbox and air filter
Lowered by Peddars
Cd Player with Ipod Control
EM1 style tailights
Hids blue headlights
Sideskirts
Everything else is stock.....
The rego is due on July
Being honest that i can...The car Is listed on revs, but nothing to worry as long you rego your car in time then you should be fine..Im selling this car very cheap anyways.
Asking for $5000 FIRM
reply to this thread if interested..or private message me then i'll give you my phone number
email: [email protected]
cheers!
post-58930-0-08012600-1305360590_thumb.jpgpost-58930-0-93507800-1305360611_thumb.jpgpost-58930-0-39788200-1305360645_thumb.jpgpost-58930-0-41848900-1305360647_thumb.jpgpost-58930-0-47982900-1305360815_thumb.jpgpost-58930-0-53917100-1305360817_thumb.jpg
Edited by LeCoq
https://www.sau.com.au/forums/topic/364244-for-sale-red-honda-civic-coupe-ej8/
whys this forum so dead!??! BUMP!
its not dead its just that most members on here are after turbo skylines not NA civic's.
BTW is the B16a2 an engine swap or does the car originally come with it?
Also may be intrested in buying if its stilll for sale in about 4 months..
a few more pictures of the whole car. not cut of quarters and some interior shots might help your cause, who did the engine conversion, how long ago?
also.. why does the odometer show 128,000 when you say it has done 138,000 is that a typo?
Edited by Yts
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
