Hi guys,
I'm new here, thought I would put some stuff up for sale.
All parts from s14a 1994 200sx
*4 x Stock rims- Sprayed in gloss black, all in very good condition except 1 which has slight gutter rub in one section and small section of pitting in middle.
Missing one centrecap, w/2 x tyres @ 50%, 2 tyres @ 5%. $220 ono
*Stock rear spoiler- Moroon in colour, slight crack in rear, easily repaired with putty. $30 ono
*Impul Tuned ECU-(high power control unit) Working, have tested in my car. On the Impul website and a couple of others it retails for about $2000!! Tuned for manual blacktop sr20det w/VCT. Make me an offer as i have no idea what they are worth in Aus. It is a s14 ECU with Impul daughterboard in very good condition.
Have pics of all these items, located 60kms Nth of melbourne.
https://www.sau.com.au/forums/topic/364308-s14-200sx-parts-for-sale/
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
