Just curious... for the people with the new style RSM (blue screen) does the actual RSM need to be plugged in for the car to work (like can the car/ecu still work 100% with the RSM plugged in).
The RSM has a permanently connected cable which has a plug at the end of a 2ft cable. Their is then another plug with another 2ft of cable which is what actually connects to the ECU wires. If I was to connect it all up but then disconnect the RSM would everything still work or would it leave some of the loops open?
Are you confused? I'm not far off it... :)
https://www.sau.com.au/forums/topic/36443-apexi-rsm-installation-question/
I think you may find that the speed signal doesn't get "passed" on to the ECU...
In my experience, the speed sender on the gearbox passes the signal to the dash cluster... This drives the speedo... The signal is then passed on to the ECU...
The RSM intercepts the signal between the dash and the ECU...
There are two methods of wiring the RSM IIRC... One where the signal is intercepted and the speed cut can be changed... And one where the signal is tapped and the speed cut remains factory...
I'm unsure what happens when the speed signal doesn't get passed to the ECU? Perhaps those who have cut wire 53 will be able to elaborate on the effects of having no speed signal to the ECU...
All the other wires should be fine...
i agree, the only problem would be the speed signal as the rest only tap in to what the ECU sees whethere the RSM is there or not. ie, the speed wire is acually cut and runs thru the RSP and then to the ECU.
I can't see this being a problem though if the ECU doen't get the speed signal.
Because it must be altering it or removing it altogether for the car to work over 180km/h.
If you are still worried about it, wire it the alternate way which only taps into the wire without doing the speed cut. Then it would DEFINATELY work plugeed in or not.
I've got one so i guess i should unplug it and give it ago but i'm stuck at work now for 12 hrs :)
Edited again....
What im trying to do is have it so that i can disconnect the RSM 'while' im at work (to try and help prevent theft etc). So when im driving i'll -always- have the RSM connected. I was just thinking that by connecting <-> disconnecting the RSM it might muck up the ECU or speedo or something while the car is sitting there off.
Should be no problem at all to disconnect when nt running I'd say.
Won't affect anything.
But anyway...what i do is a couple of matching velcro sticky strips.
One on the RSM and one on the dash in front of the standard speed dial.
Just enought room to see kms,boost and fuel...perfect!
The everytime i park, just 'rip' it off and place it under the dash where the pdeals are.
Sort of a reverse type shelf there and balances there fine.
Well I plugged it all in and it switches on etc and is working but the only problem is the wire that im sposed to splice for the 'revs' does not exist on my harness, its empty???
Has anyone here installed 1 on an RB25DET recently?
Yep, did mine myself (and my brother) and if it's blank, your not reading it right.
We read everything quite a few times and made notes on colors positions of wires etc....
Did it all once and switched it on...
First thing we tried was Revs and all worked fine.
Maybe you're reading the wrong ECU diagram but it's definatley correct
Or maybe you've got it upside down but i doubt that as you've got the power working..
Good luck :P
Well the English (USA) is a different diagram number but their is only 1 - 16P-20P-20P harness in the entire Nissan section and its for RB25DE/RB25DET. In the Jap book it came with its a diff diagram numb but the same picture.
I'll have a look at it again this afternoon (in the daylight :P )
Can anyone tell me what colour their 'speed' wire is on the ECU harness? I have no issues getting power to the RSM but cannot for the life of me get a speed signal.
I have a '95 R33 GTS-t Series 1
Ok still trying to figure out this stupid thing.
Attached is a pic showing that I do not have a Rev output wire like shown in every single manual I've read. Are their any other wires nearby that I can connect the Rev wire too?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
