sit really well on my 4 stud R32
currently sitting on low profile 215's all round with lots of tread
reasonable condition, note one rim has polished chrome trim so its not as shinny as the others but hardly noticeable
located south east Melbourne
need these gone asap!!!
willing to let them go for $400 with tyres !
0408391831
  • 3 months later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
