why the hell would I buy a Lexus? 270,000km owned by Qoc Nguoc Phan Tran who services it at a backyard Gull servo mechanic
Signature worthy. Epic!
I think the electronic shifting is awesome, I just want a manual so I can drop the clutch and have a finer control over gears.
Also, I think majority of Skylines in Australia that are sold on are thrashed and f**ked, or just not worth the asking price. Why when you can buy something in much better condition in Japan, import it and comply it and still have less KMs and pay less.
  • Replies 59
Andrew - am saving up to import again, I have not purchased the car yet obviously, but yes... In about a year or so time I will have a crown majesta..
And haha, eps... Why do you have that name that's gonna get so confusing haha
But it's true though. The only people that buy Lexus are Chinese or rich Vietnamese. And Jewish people,
And they seem to REALLY drive them. A LOT.
That's not racism. It's just fact. Oh and Indonesians love the third gen GS and the RX too. Haha
^^^ this. . . i have a auction sheet (with pics) in front of me and i doubt that i will be buying a sedan in aus, not when there are cheap /low K examples waiting to be snapped up in japan
Most Japanese cars are in good condition and well worth the little extra wait :)
Definatly worth the wait , ive been in contact with Kristian from IRON CHEF , so far so good, he has sent me some more auction sheets and there are PLENTY of good condition sedan worth waiting for, nearly all autos ( but i dont mind that as i believe the fluid filled auto trans would help dampen engine harmonics) and only a few manuals, most grade 3.5 and up
Put it this way, in the import market... A 10 grand total budget will likely yield you quite a good black coloured ER34 with a lot of fruit on board like wheels etc....
And more than likely depending on the exchange rate at the time, will PRObably get you change back from the transaction ...
But either way... Importing an ER34 into WA is feasible because the market here is so inflated for them... So it actually makes sense. Personally I'd get a Toyota because I think they're built much better.. :)
My other piece of advice? Stay away from WA compliance shops. I hear good things about a particular shop that's on here that DOES lurk these forums and that shop IS good however stay the hell away from that yellow shop with the kangaroo in overalls on the logo.
That guy is a prick. A grey haired... Greedy .. Lieing... Prick.
which is the good shop you speak of?
GT -> Basic 2L
GT25 -> Same as GT, but with 2.5L engine.
GT-Four -> Same as GT25, but with AWD
GT-x -> Same as a GT25. Equivalent to a premium model equipment wise, ie. factory privacy glass, double din "premium sound", xenon headlights, front strut brace, optional LSD, optional GTt wheels.
GTt -> turbo model of a GT25, with big brakes, HICAS, LSD
GTt-x -> turbo model of a GT-x, with big brakes, HICAS, LSD
GTv -> Same as GT25, but with big brakes, HICAS, LSD
Thanks Mark, thats the sort of info im after :thumbsup: these sedans are just as well equiped as the coupes . .just with two extra doors
Prices seem very unpredictable of late. We've watched cars go for a lot more than they should. Last week I was bidding on a 3.5C, auto 4 door GT-V 50,000km that went for Y650,000 - so about 15.5k AUS landed and complied.
The week prior a 4.5B, TV2 4 door manual GT-T 65,000km went for Y1.9Million. That is silly money. That is 34 GTR Non-Vspec type of coin.
It is hard to pick a great condition cheap car at the auctions currently. I have found cars locally to be very well presented, with low km's and very cheap. I'm considering looking locally for my 34 4door instead of at the auctions for this very reason. Why pay 16k L&C when I can pick a comparable car up loacally for 4-5k less?
Ive found the opposite so far, ive gone thru 200 pages of cars for sale on SAU (some with mods) and a lot of auction sheets and after comparison i reckon i will come out on top by importing a skyline
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
