Event Day - Hillarys Boat Harbour To Fremantle On The 31St July 2011
Hey Guys we've organised a Day Event from Hillarys Boat Harbour to Freo here is the link on facebook: www.facebook.com/event.php?eid=227770757239289
If you want some professional quality photos of your car , WHBphotography has offered to take 5 photos for $5!! Heres a link to our page www.facebook.com/WHBphotography
Thanks alot guys and hope to your Skyline there!
If you guys have any questions please call Will on 0415 513 196, or Michael on 0430 745 641 or contact WHBphotography on facebook.
Cheers
Hey guys make sure to invite all your friends on Facebok to the event;
http://www.facebook....227770757239289
post-85392-0-50609700-1307452793_thumb.jpgpost-85392-0-62184200-1307452839_thumb.jpgpost-85392-0-91682500-1307452870_thumb.jpg
cheers
Great photos!
I will probably miss out on this event with work. Also, I can't seem to find the Facebook page.
Hey guys,
As Eric posted, the event is on Sunday the 31st of July 1.00pm to 4.00pm. The time is just an estimate, so it may run later that 4.pm. It would be sweet if we could get some sunset shots in.
Cheers for the enthusiasm guys!
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
