hey guys up for sale i got a pair of garrett gt 25/60r -5 turbos with hks split dump pipes, turbos came out of my gtr and are in fantastic condition, no shaft play what so ever, excellent upgrade for any street gtr looking for some great power figures, got a pair of HKS 25/30 turbos for myself so no need of keeping these,
willing to seperate the turbos and dumps,
price - $1900
contact 0412862091 for any further information
cheers
Facebook.htm
front of turbs.htm
Edited by gdzlar1
guys!! buyer fell through as something came up, these are known as the gt28/60r -5, no shaft play so back up for sale $1400, these retail at $2800 and no play with them what so ever
cheers
