Bought a radiator from the US (dumb yanks..) and it wasn't the right one for my car. I was told it would suit my R34 GTR, but it is about 50-6mm too short in height..
It was sold as a radiator to suit R33's and R34's, regardless of engine (so GTS-T, GTR, GTT). Obviously this is not correct, so i would have to measure it against what you have if you're keen to see if it would suit.
It is brand new, with no liquid passing through it, but does have some bent fins from trial fitting in my car. Would like $400, which is a great price considering the quality of these units (lifetime warranty) and the cost of overseas shipping, located in Sydney.
Overall Size: 26.4" x 21.8" x 2.07"
Core Size: 15.75" x 25.51"
Rows: 3
Inlet: 1.4"
Outlet: 1.4"
Core Thickness: 1.57"
Tank Wall Thickness: 2mm
Fill Neck: 1.25"
Drain Plug Thread Size: (M16) .06"
Drain Plug Thread Length: .047"
Purchase Includes:
Mishimoto Radiator
Mishimoto Radiator Cap
Magnetic Drain Plug
Limited Lifetime Warranty
Radiator is fabricated from 100% aerospace grade aluminum. Features brazed aluminum cores with no epoxy joints
High efficiency tube and fin design increases surface area to dissipate heat effectively
High quality heli-arc welds and sturdy construction, perfect for performance vehicles.
Direct bolt-on replacement for stock radiator
https://www.sau.com.au/forums/topic/365897-mishimoto-radiator/
Ok, so i have gotten to the bottom of this. I can confirm that the radiator is for all R33's and R34 GTT. It is really well constructed, and it immediately shows when you look at it in person.
Will not suit a 34 GTR because ours are 50mm taller in height.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
