Item Summary: 1993 NISSAN 180SX, HEAVILY MODIFIED JDM STYLED 180SX HKS GT-RS 250RWKW
Postcode: 0810
Odometre: 6,628 kilometres
Asking Price: $19,500
Condition: Used
Reason for Selling: getting a work car
Delivery Methods: PickUp
Contact Info: James: 0423472806
Extra Information:
ENGINE BAY:
FULLY FORGED/BORED/SLEEVED REBUILD - 6628KMS
TOMIE INTERNALS
HKS STAGE 3 CAMS
ADJUSTABLE CAM GEARS
SOLID LIFTERS
HKS HEADGASKET
GREDDY PULLEYS
TOMIE SUMP
SPITFIRE COILS
6 BOOST MANIFOLD HPC COATED
PLENUM & ALL ENGINE PARTS HPC COATED
NISMO 740CC INJECTORS
GREDDY REMOTE OIL FILTER/COOLER SETUP
ALLOY 'ARE' RADIATOR
ALLOY GREEDY INTERCOOLER
HKS SSSQ BOV
Z32 AFM
BILLION PWR STR CAN
HKS GT-RS TURBO
CUSTOM ALLOY PIPING/CATCH CANS/RAD OVERFLOW
HKS BRAKE STOPPER
HKS STEERING SHAFT SPACER
NEW SLAVE & MASTER CYLINDERS
PLENTY OF CUSTOM FABRICATION THRUOUT
HID HEADLIGHTS 8K
GIZZMO PLENUM GASKET
S15 TRIPPLE LAYOR GASKET
BLITZ NUR SPEC EXHAUST
BRAND NEW AC SYSTEM
ENGINE SHOCK ABSORBER
NEW NISMO ENGINE MOUNTS
GREDDY BOOST CONTROLLER
GREDDY RAD HOSES
APEXI POWER FC
CUSTOM AIR DIVERSION
NA S14 TB
CRAIG DAVIES THERMO FANS
CLEAR CAS COVER
HPC ROCKER COVER
EARLS FITTINGS
DRIVELINE:
BRAND NEW EXCEDY HYPER TWIN PLATE CLUTCH (2000KMS)
B&M SHIFTER
CUSCO 2WAY DIFF
BRAND NEW CLUTCH CYLINDER/BRAIDED LINE
BODY:
RECENTLY RESPRAYED 2PAK PANDA PAINTJOB
HAND METAL FLARED GUARDS F/R
VERTEX KIT ALL ROUND
TYPE X TAILLIGHTS
DELETED SPOILER & AERIEL
GANADOR SIDE MIRRORS
TINTED WINDOWS/NEW GLASS
TINTED INDICATORS
SEAM WEILDED CHASSIS WITH BOOT BRACING (FACTORY LOOKING)
2PAK SILVER ENGINE BAY/INTERIOR PAINT
ICE:
KICKER TWIN 600WRMS SUBS IN INCLOSURE
DRY CELL BATTERY BOOT MOUNTED
JAYCAR MONOBLOCK AMP
JAYCAR 2 CHANNEL AMP
ROCKFORDFOSGATE SPLITS
PIONEER USB/AUX/IPOD HEADDECK
SUSPENSION:
DRIFTSHOP REAR 28MM SWAYBAR
DRIFTSHOP CASTOR BRACE
DRIFTSHOP CAMBER ARMS
DRIFTSHOP TOE ARMS
DRIFTSHOP TRACTION RODS
DRIFTSHOP ALLOY SUBFRAME SPACERS
TIEN TIERODS
TIEN TIEROD ENDS
TIEN TIEROD SPACERS
TIEN CASTOR ARMS
BC COILOVERS (BRAND NEW)
CUSCO REAR STRUTBRACE
S14 HYPERKNUCKLES WITH BUILT IN ROLL CENTER ADJUSTORS
REAR ROLL CENTER ADJUSTORS
BRAKES:
S14 5 STUD F/R WITH BRAND NEW S14 HUBS & BEARINGS WITH NISMO EXTENDED WHEEL STUDS
BRAND NEW DBA SLOTTED DISCS
R34 CALIPERS WITH MU'SECRET PADS
BRAIDED LINES
WILLWOOD HYDRO HANDBRAKE IN FACTORY POSITION (CYLINDER IN CENTER CONSOLE)
WHEELS:
R34 GTT 17'' RIMS
4 NEW BRIDGESTONE POTENZA 235/45/17 FRONT 245/45/17 REAR
INTERIOR:
NEW CARPETS
PERFECT DASH
R33 GTR SEATS
APEXI RSM
GAUGES PILLER MOUNTED
CUSTOM KILL SWITCH
GREDDY TURBO TIMER
OMP SUEDE STEERING WHEEL
NISMO CLUSTOR BRAND NEW INSTALLED WITH NEW ENGINE READING 6628KMS
APEXI EXHAUST VALVE CONTROLLER
BLUE LED'S EVERYWHERE
PERFECT INTERIOR
THIS CAR HAS HAD OVER $50,000 SPENT ON IT. CAR IS IMMACULATE INSIDE AND OUT. EVERYTHING IS QUALITY AND WELL CARED FOR. NEVER TRACKED OR DRIFTED. THE MOTOR HAS BEEN BORED OUT TO 2.1L MAKING THE EXHAUST NOTE ONE OF A KIND.
NUMBER PLATES NOT INCLUDED.
https://www.sau.com.au/forums/topic/365932-nissan-180sx/
  • 3 weeks later...
  • 3 weeks later...
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
