Parting Out R31 Passageitem Summary: Parting Out R31 Passage, Location: Qld: Brisbane Postcode: 4208 Asking Price: $4,000 Condition: Used Reason For S
Item Summary: Parting out R31 Passage,
Postcode: 4208
Condition: Used
Reason for Selling: lost interest
Delivery Methods: PickUp
Contact Info: Josh 0400641699 TEXT ME AS I WORK A LOT AND DONT GET TO THE NET MUCH!!
Extra Information:
Hi all, Parting out a R31, Its a IMPORT 86 Passage Auto with a Red Top RB20. It's shattered a piston so the engine is stuffed. Apart from that and a few hail dents on roof boot and bonnet its very tidy. Would be awesome to buy as is and put a 25 and Manual in it. My olds just want it gone as they want to get a new car and dont want to invest anymore money into it.
Here are Prices for Items of interest for parting out.
*Haltech E11v2, No loom $1400
*Custom 2.5 inch SS Turbo back exhaust $400
*4x 16 inch simmons Wheels with Roadworthy Tyres $500
*Splitfire coils suit silvertop RB20 (20,000 k's old) $300
*R32 Turbo $200 Stealth Series $60
*Complete Passage Interior inc carpet VGC $650
*Sard Fuel Reg, $75
*Import 31 Tail Lights and boot Garnish $150
IF YOU NEED ANY PARTS TEXT ME AND I"LL GIVE YOU A PRICE.
STRIPPING A COMPLETE CAR SO CHANCES ARE I"VE GOT THE PART YOU NEED!
ALSO FEEL FREE TO MAKE AN OFFER ON IT AS IS!!!!!!
All Pm's relied,
So far the simmons are SOLD, Tail lights SOLD, Rear Cradle and Diff is SOLD PENDING PAYMENT. Boost Tee SOLD
Also Sold are the exhaust, Splitfires, and DIFF and headlights.
Still have all the panels and interior.
  • 3 weeks later...
Hey mate, at the moment the interior minus instrument cluster, all ext panels, and motor and box, and the haltech.
    • Sorry I didn’t explain myself properly, by free revving I meant if I just floor it, it gets to 7kish and will start to break up/not hit limiter properly, off boost I’ve driven the car until near on empty. I have a fuel pressure gauge mounted in the engine bay, holds fuel pressure consistently full tank or half tank even when revving, and no the pump sound doesn't change. all the fuel lines inside the tank are fairly new but will look into it, could that also be an issue with the lines outside the tank ?
    • Yeah maybe I got a bad batch that only lasted 6 years. Or conversely maybe I got a good batch that managed to last 6 years.    Either way I have sourced a set of OEM hub/bearing assemblies  so I keep hearing! Even from life long mechanics. Apparently this failure is unheard of…
    • I am trying to understand how that even happened to the hub... wtf
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
