Up for sale is my entertainment Laptop. My DV6-2114Tx. I just wanna see how much you guys are willing to pay for it, sale is in VIC
its specs:
  • Intel Core i5-540M (DC, 2.53GHz/3MB/2.5GTs)(turbo boost up to 3.03ghz)
  • 4GB DDR3 RAM(i can upgrade to 6 gig if requested)
  • 640GB SATA HDD
  • Blu-Ray ROM with DVD+/-RW Dual Layer with LightScribe drive
  • 15.6 inch HD (1366 x 768) LED Backlit BrightView display
  • nVIDIA GeForce GT 230M (discrete, 1GB dedicated)
  • 10/100/1000 LAN, 802.11 b/g/n WLAN, Bluetooth, 56K Modem
  • SRS Premium Sound with Altec Lansing speakers, Webcam, Digital Media Card Reader
  • 1x HDMI, 1x VGA, 3x USB, 1x USB/eSATA, 1x FireWire, 1x RJ-45, 1x RJ-11
  • AC Adapter, Battery, Power Cable
  • Windows 7 Home Premium pre-installed
  • (p/n: WF601PAR) (SN:GOL-4977) (650006-58)
  • The laptop still has the plastic cover at the rear, minimal scratches, and it looks pretty much new.
  • Has no trouble running crysis or black ops.
  • i purchased it last year for over 1700.
Reason for selling is that, i've fallen in love with the Beats envy which is $2100 at harvey norman. It comes with a pair of $300 headphones that i was gonna purchase anyway.
i've taken alot of care with this laptop, and its never had any issues before.
Again, i just wanna see how much you guys are willing to spend on it, if its not enough, i'll keep this laptop and puchase the beats on flexi-rent.
  • 8 months later...
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
