Hey guys. Sorry I've never posted, been a member for a while now but haven't been too active.
Hope you can welcome me to the communityl I left a post in the newbies section of wasteland.
I have a R32 Skyline GTR that is having problems(lots of problems :()
When I rev my engine above 4-5K, and let it drop, it almost stalls. It goes down as low as 500RPM and you can barely hear the engine for a moment and then it starts back up.
Any idea?
I have recently replaced all spark plugs to PRF6A-11 with .8mm gap, also replaced two coil packs that appeared bad, and I also addition taped my current coils with electrical tape although there were no cracks, and replaced the fuel filter.
I also have a hesitation and complete loss of power around 5K that I was hoping the above could fix, but I can't get it out on the road to test it for a couple weeks.
In regards to the almost stalling problem I have found these could be the problems:
Coil packs(Need to test), wires to coil packs
Vacuum leak
Over-Rev (Bent valves)
Bad injectors
Fuel pump
Head gasket
Throttle body
IAC valve?
I do see a little oil where my spark plugs sit if that matters at all
Can you list thess in order of most likely, and if you have any to add?
In regards to the hesitation problem:
Mostly the same things as listed above except crank angle sensor or o2 sensors could need replacing.
The car runs extremely rich. The mods currently done are a Greddy VTA BOV, N1 turbos @ 1bar, larger intercooler, oil cooler, 300lph fuel pump, apexi filters, trust dump, 3" apexi exhaust, straight pipe, that's about it.
It seems to have problems with low fuel when going up hills, and I can't seem to empty 3/4 of the tank but I could be hallucinating and my gas gauge is broken.
I cleaned the MAF's already so I don't think it's them.
Any help is greatly appreciated. It's summer time and my baby just keeps sitting in the driveway, I'm starting to get really sad :(
Edited by gzrecoil
I should also note that one of the spark plugs that I put in is very charred.
Although it was at 1.1mm gap, now .8mm, the car was never driven since they have been put in, only idled about 4-5 times to warm it up.
See attached picture below. Charred is on right, all the rest look like the one on the left. I wish I knew which cylinder this came out of. I at least know I put it back in cylinder 1.
Edited by gzrecoil
Hey mate, the stalling issue sounds like one of two things so far:
- Vacuum leak (check all your hoses and piping)
- BOV (I presume it's a vent-to-atmosphere one?)
If you don't have an aftermarket ECU (be it a full standalone like Power FC or a piggyback or a re-mapped stocked ECU) then I'm fairly certain that it would eliminate your running rich problem, hesitation problem, as well as your stalling issue (provided it's not a vacuum leak and is BOV related).
As for oil on the plug, that doesn't sound very good but have you got a compression test done?
Yes I do have a VTA BOV, a greddy one. I don't know anything about how it's hooked up.
I will have to figure out all the vacuum hose locations and trace them I guess, not looking forward to that.
I just bought a compression tester so hopefully I can test tomorrow. Just need to locate where the CAS is to remove it for the compression test, I'm a noob lol.
Ahhh I see. More than likely it's your BOV that's causing the stalling issue. If you have the stock one, chuck it back on and check if your car is still playing up :) but I'm almost certain it's the BOV playing games lol
As for the CAS, it's the round metal thing poking out of the cam gear cover :)
Thanks. I did a quick google search for CAS last night and realized that.
After reading a lot about VTA BOV's I agree this very much could be causing the problem since I'm still running MAF's.
I wish I had enough money to take the jump to a Power FC D-Jetro w/ MAP sensors but I think I'll take the cheap route and try to find some stock recric BOV's.
Will post up my findings when I can find some to use.
You don't neccaserily have to go MAP sensors to run a vent-to-atmosphere BOV. Even just a piggyback can be enough to get around the stalling issue as the tuner can subtract fuel to avoid it from stalling :)
But yeah, cheapest option is stock BOV. Otherwise, almost any kind of piggyback ECU will do the trick :) I had the same problem a little while ago too but I chucked in a Greddy E-Manage (which I'Il be selling in the near future *wink wink nudge nudge* haha) and got it tuned and it's all happy now :D
We'll see... I would love to have something but haven't had the money.
Curious, I'm being told if I have the right size flange I can make the greddy bov recirc? If that's the case I wonder if I should try to acquire stock piping or make some myself and buy a flange somewhere.
So confused... Picture of my BOV attached.
Edited by gzrecoil
Im very sure its the bov. My old s15 would stall or drop idle after acceleration then coming to a complete stop; my fix was to put it into neutral and give a quick rev when slowing to a stop.
Id definitely pop on a stock one and if thats the fix then pick up a stock gtr bov to put on
If I were to buy the attachment above to recirc the Greddy Type RS where do I run the piping to?
I don't have the stock recirc piping or anything so I assume I will have to fab it.
Would really appreciate your guys help, I really could use this car on the road for the summer :)
-Recoil
Ok, so i see it goes in after the MAF, I'll have to look tonight to find out where I can run a tube. I haven't noticed any open plugged holes before.
My BOV is on the left side of the motor by the battery, and intake is on the right.
I would have to run a tube across or under my motor, or relocate my BOV (No clue how to re-locate)
Should I buy an SAFC or an idle stabilizer or should I just go re-circ?
I could care less about the noise, reliability and cheapness of fixing the issue are the most important things here.
Edited by gzrecoil
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
