My rear subframe sits about 15mm to the right hand side, I know a few R33 have the same problem and i have been told you can fix it with new bushes but also been told there is no fix.
Just wondering if i throw a 10mm spacer on the left side to make it look even will it throw anything out?
my aligntment is fine and car has never been in a crash.
https://www.sau.com.au/forums/topic/366596-r33-rear-subframe/
  • 1 month later...
Spacers are illegal no!.
so if you have an accident and get cought with it on you car then good by insurance .
If subframe sits offset then wouldn't you have at least 15+mm of play in subframe movement L&R.
Handle poorly, wanders etc.
try turning corner in direction that should shift frame to opposite side and park before straightining up and check to see if its moved, chances are it will be the same though as it's proberly setteled there.
put it under pressure driving and I'd safely bet it's moving around.
sounds like time for a bush freshen up, have someone quailfied you trust to take a look at it
  • 7 months later...
  • 2 months later...
Alloy.
The alloy bushes will lock the old bushes into the correct position which will fix your problem if it is related to the mis-alignment or degradation of the old bushes
The poly pineapples don't lock the old bushes into place they just apply pressure to them and to be honest don't really acheive much at all.
I got a nice set of alloy bushes off fleabay for $50 (cheaper than poly pineapples) and they can be easliy fitted in an hour (there are some good DIY threads in that section)
Good luck with it.
  • 1 month later...
I thought about alloy locks but woll that make it too stiff for a daily?
If you have crazy stiff jap coil overs, then yes maybe. If you have decent quality shocks and springs, then it shouldnt be too bad... Its what i had to do :) at the same time of fitting alloy bushes, i also put in a rear strut brace, tied in the rear nicely.
yeah I think im going to try them, are there any particular brand or are they all the same? i found a set local for $90. I have 8kg rear springs with strut brace and gtr sway bar so hopefully its not too bad, if it is ill get used to it anyway.
Nah still no fix, a few people have changed wheel aligner and that helped but mine is too far off to be alignment.
Mine looks the same with 9.5" rears +38. One flush on one side and the other sunk.
I thought my rear ride height wasn't equal so I went back to a suspension shop and eventually we noticed under the car that the cradle looked all tightened to one side, so the guy tried loosening off a few major bolts and prying it back the other way but it didn't budge. I suppose you'd have to undo it a lot more to move it level on both sides.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
