hey guys here some stuff for sale from my R33
window wipers for front and back $30
nissan skyline R33 floor mats no front mat's only back mat's $30
R33 boot carpet to hide back lights $10
Monza mspec seats $300
R33 S1 stock seats $200
R33 back light lift side cover $10
Intercooler kit is straight "plug in and go.. and no there anything u need to modify to get the cooler to fit.. yes the
cooler work.. and no cracks in the pipes or cooler..
yes it come with mounting brackets and all u need 2 get it runing $350 that with free post any in AUS
R33 AIR CON FAN bit of the front cover is missing as you can see in the pic but still work very good $40
sorry i will not give free post..like i said i will post anywhere in AUSTRALIA at the buyer own expensive. Thanks
post-81807-0-64554400-1306127964_thumb.jpgpost-81807-0-85197700-1306127925_thumb.jpgpost-81807-0-92267800-1306455025_thumb.jpgpost-81807-0-48924500-1299194862_thumb.jpgpost-81807-0-20357300-1300065778_thumb.jpgpost-81807-0-15270200-1299195082_thumb.jpg
post-81807-0-96838000-1299553489_thumb.jpgpost-81807-0-83329900-1299553472_thumb.jpg post-81807-0-90502900-1300065644_thumb.jpgpost-81807-0-43592700-1300065691_thumb.jpgpost-81807-0-29807500-1300065552_thumb.jpgpost-81807-0-64623800-1300065435_thumb.jpg
Edited by MAD R33
https://www.sau.com.au/forums/topic/367244-r33-parts/
if some one buy this stuff that will be good as my car not on the road because the cops defected it and i need the money 2 buy stock R33 bonnet and to pay 2 get it back on the road thanks
https://www.sau.com.au/forums/topic/367244-r33-parts/#findComment-5858395
Monza mspec seats $400
https://www.sau.com.au/forums/topic/367244-r33-parts/#findComment-5883018
hey, i seen you made a funnel near your cooler going to cooler your afm more.. i was going to do this if i did not have a return flow and use that extra hole.. did you cut a extra hole to pop in your extra cooling to your afm?.. sorry, i had to ask?.. thanx.. oh, how old is the cooler/piping?, if its ok to ask, what was the reason for removing it?, the over the engine cooler setup?, always wondered which flows beta..
https://www.sau.com.au/forums/topic/367244-r33-parts/#findComment-5895604
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
