found out that Nismo use Motul 300 15W/50 synth - $75 for 4L from autobarn
anybody running this?
got recommended to use Omega 15W/55 - but that was by a japanese D1 driver and mechanic - and the stuff isnt available here, and aparently its bloody expensive even in Japan
So should i be doing an oil flush every oil change? I use castrol formula R 5-30w and change every 5k with filter.
I have heard that the Castrol R is reasonable and a big improvement on previous oils.
As for the flush, it should be done every so often, you can usually tell when you need to do a flush.
If you change your oil and filter after letting it almost completely drain (there will obviously be some remnants in the oil system) and you put in new oil and less than 100kms and you pull the dipstick and its dirty...then you need to flush.
I have also found Castrol oils to be crap especially in relation to turbo engines...maybe its the running through the turbo that breaks them down, but on NA cars I have never had a problem.
I now run Motul 4100 turbolight and previously ALWAYS ran Mobil 1, but still needed to flush the system twice after 15,000. I think I must have just got a bad batch of mobil 1...but I will now stick to the motul, always used it in my bikes so I have a basis to go by, and after 2,000km it is still nice and clean...
flush is not needed every oil change...just remember to drain the oil while it is still reasonably hot, it will drain much quicker taking more rubbish with it also will drain more completely.
I don't like Castrol for a turbo either,, Have been using Shell Ultra full synthetic. Thinking about changing to Motul
Well guys i have used shell ultra fully synthetic in my 32 gtst when i had it and in my 33gtst
when i had that and now i have a 33gtr v-spec and still use the shell ultra and its kept
my engines running great. Alwasy changed it every 4-5000km with a new filter.One thing
i have noticed with the shell ultra is that even when its time to do the oil change,the shell
still looks very clean.I have a friend that runs the shell ultra in his porche gt3 and he said him and his other porche mates in there club only use the shell ultra.I know that porche and ferrari recomend shell.Anyway that works for me.
Enrico You will be able to change no worrys at all.A good thing to do when changing oils is change it once with the new oil and filter, then do another change again at about 1000km, then just about all of the old stuff will be gone. One other thing is, that a mate of mine was
running castrol in his 33gtst and every 5000km when he changed it, the oil was black and had no body left in it.When he changed to the shell ultra ,i've seen the oil that was dumped out at 5000km this time and it was still so clean. HE WAS SOLD!!!!!!!!!
Speaking of oil filters, I noticed this product at 'Jamboree' on Saturday....
http://www.mrtrally.com.au/performance/filtermag.htm
I guess its pretty logical but comes at a price (meaning it could actually make a difference, or they are just cashing in on something that hasn't been done before).
Hi Guy's
If you change your oil often you shouldn't need to flush the engine.
I work as a sales rep for one of those oil companys you have mentioned and let me tell you that 5000kms in a road car on any good synthetic oil is nothing. If you have to flush your engine after 5000kms somthing is wrong.
We supply many truck fleets that run up around 70000kms between oil changes, and their dirty diesels, even these guys dont flush their engines between drains.
ASHLY
Hi Guy's
ASHLY
The thing is, my car did 80 000km with god knows what oil and probably without any flushing. So now that it's all clean, I won't be flushing it for quite some time, if ever again. Good quality oil should contain enough detergents to keep the insides clean and I plan on using just those detergents from now on to keep it clean until I see something wrong.
For anyone that thinks that just because an oil is "cleaner" after an oil change, you should probably revise that thought. Oil is supposed to turn black as it absorbs soot. If the oil stays clean, that means the soot is going elsewhere. And I don't remember the last time Ferrari produced a turbo car. Why would you go off a recommendation for a non-turbo car for a turbo Skyline?
Also, I have never read a non-biased review which said that Shell Helix was anything other than an average oil. Perhaps a bit above average and almost certainly better than Castrol, but really nothing special compared to the better synths. Don't judge the oil quality by its colour after changing, is all I'm saying.
Forget all the marketing hype and just do some research outside the advertising. I didn't buy the Fuchs oil because of marketing or advertising, I bought it because I heard from a few sources that it was a good quality oil which many other companies buy their synthetic base from, and that was good enough for me. If it turns out to be dodgy then I'll have to research more and find out which companies use Fuchs, and also rule them out. But I'm pretty confident that it's above average in quality.
There are several reviews on the web about oil. Probably the most common comparison is comparing Amsoil to Mobil 1, because Mobil 1 is meant to be the premium synthetic oil (and almost the same as Fuchs synth). Everyone should probably be running Amsoil if they could afford it, but all of the comparisons are slightly biased in favour of Amsoil. Mobil even refute some of the tests that Amsoil use.
I personally think there is not that much of a difference between Mobil and Amsoil after reading up on both of them, provided you do regular changes and don't subject your engine to extreme temperatures. I'd rather save a few bucks between changes and be able to just pick a new bottle from any spares shop, than have to send away for it every time. In the long run I doubt I'll see any difference.
well, it makes sense to flush it after 80000 kms on the same oil.
i dont want to get involved in a comparison between different oil companys (for obvious reasons). But i can get technical or general information on different Fuchs lubricants if you want.
ASHLY
JimX
I realize that oil is spose to get black but there is a difference to oil getting dark to an oil that looks filthy black.The other thing was i wasn't saying that shell ultra was the best of the best,all i was saying is that the shell ultra has kept my cars very clean.The whole reason i have stayed with the shell ultra is that a couple of years ago when my r32 motor was stripped to do some mods the inside of the motor was very clean.So i kept useing it.
One other thing is i know Ferrari dont run turbos but if they are running it in a $200000 plus car it cant be to bad.Also i have mates running it in there turbo porche and it does fine for them.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
