I have my 1990 Series 3 Nissan Exa for sale.
Located in Castle Hill, NSW (near parramatta)
I have owned it since October 2010, and it has been a great car.
It has rego until the 28th of October!
It has tinted windows (10% I think), central locking, 4 speaker stereo (With USB, and SD card capabilities), power windows, 4 wheel disk brakes, and a 4 inch exhaust tip (can supply XFORCE cannon if needed)
16 inch TSW Evo R alloy wheels in good condition (a bit of gutter rash) and are wrapped in great tyres.
The tyres are in excellent condition, with the rear tyres (Kumho KU25) having about 80% tread, and the fronts (Firenza's) having 99% tread, being less than 2 months old and travelled only 1500km
2 new engine mounts were put in 4000km ago, and a new rear stabiliser bar at the same time.
It has a low km (164,000km) CA18DE engine, with new coil packs, spark plugs and ignitor module. It was serviced with all new fluids and filters in the past 300km.
Timing belt and cam seals were done in october, about 12,000km ago.
It has been extremely reliable, and it will be a shame to see it go.
AFTER $2500, BUT PRICE IS NEGOTIABLE
Call or Message on O466682248
Edited by eclipse
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
