Just noticed how much the roofline on these looks the same as a mustang but the trailing edge of the window is metal on the ford instead of glass like the mazda.
Thats one great looking Mazda
  • Replies 89
Posted Images
ok.....the guy on the right is my mate johnny from restoblast,he blasted the car inside/outside and underneath.It was put on a rottisere,made new floor pans and hand beat the patterns in them.He also remade the left inner skirt and various other parts for the car......it had quite a big whack in the front at some stage so he also reset the chassis rails on a car-o-liner......the car has been metal filed and he has done a fantastic job...very gifted tradesman indeed
this is the underbody all resealed and textured
by the way this is just the ground coat for the Tbird....i will be doing the hang on panels very soon....then all 7 meters of it will be speed filed and blocked down.....im glad im not doing it!!I will then be painting the true colour which is a light mettalic blue,rocketing some clear over it then be blocking it down and flow coating it
i must agree.....i almost bought one instead of the rx3.....the rx4 has an agro looking front....almost finished assembling the mazdabator today....
heres the car sort of finished i didnt have the rear garnish and the tail lights...he has them....so i couldnt drive it over so jack from citywide is towing it there today.....i powered it up and down the street and man does it go fast!!!!!!i got these plates a while ago for mine but i think i will give them to him....he can mount them where he likes....we just cable tied them on the grille......these plates are ment to be viewed from the car infront via the rear view mirror ;)
i cant get the pearl to show up nice in pics but wow it looks great!!!!!!
ok so finally got a chance to strip the old boy down with the help of roy......very happy with what i found so far.....looks like the front end has never been off before....i must admit i expected quite a bit of cancer especially under the tops of the front guards on the upper rail and in the hinge pillar but looks like i got lucky....the guards themselves are excellent for a 35 year old car....small rust but a pretty easy fix up really some at the bottom of the sill behind the guards on the body,usually the bottom of the screens cop a hiding but this ones quite minimal,also i think the car has been parked nose up on a rise si some water has been sitting in the vent plenum behind the dash so some rust there.....the car is as bare as the day it was born ready to go to restoblast for bead blasting inside outside and underneath.....the nose cone is also in great condition....im very happy,i couldnt have found a more original/better car for this project and its quite amazing considering how nasty the japanese weather is.....most of the cars here in australia are far far worse....work permitting i will be hitting this quite hard after its back from being shot with plastic bead....lets see how many more holes the bead blasting finds....whoop de doo
Edited by ylwgtr2
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
