Clarion MP3/WMA/CD Top of the range Head unit DXZ766MP High Powered 53wx4
This unit was $799 brand new
Features:
53wx4 High Power
Motorized sloping Face
Detachable Face
MP3 ID3 TAG
SLOPE CONSOLE
M BASS EX
24 BIT
MOSFET
4v/ 6channel Output
AUX input
Z-Enhancer sound customization
Low-pass filter
18 FM/6 AM station presets
MP3 and WMA compatible with ID3-TAG display
CD-R/RW ready
FI VFD (Fully Integrated 16-gradation full dot VF display) (256 x 64 dot)
728-variable colour illuminated keys
Screensaver
CeNET control of: DVD changer (easy), TV tuner, 6-disc CD changer
4-volt/6-channel RCA output
2-channel AUX input with level control
CeNET iPod interface compatible
This sale is for complete headunit, wiring harness and remote, all that you need.
Comes with several full spectrum selectable LED lighting, 6 channel Rca output,AUX input, MP3/WMA suppport, 4v6CH output, and optional ipod connectivity.
Check this youtube clip to see some of the features of this head unit:
http://www.youtube.c...h?v=a1fA7Kf7TWI
Pick up from Western Suburbs Melbourne
Asking $280
Can post Aus wide for an extra $20
call/ sms Mob: 0422756270
Edited by G4orce
Hey mate,
Can you post a side on pix please so I can acertain if it will screw into the standard DIN mounting brackets?
Les . . .
________________
Features:
53wx4 High Power
Detachable Face
MP3 ID3 TAG
SLOPE CONSOLE
M BASS EX
24 BIT
MOSFET
4v/ 6channel Output
AUX input
Low-pass filter
CD-R/RW ready
Screensaver
Asking $280
Hey mate,
Les . . .
________________
Hey mate i took 2 close up pics for you, let me know if you are interested. Cheers.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
