as title states, its a power fc with handcontroller in excellent condition as it is always in the glovebox for sale. its currently in a series 2 r33 gts-t so it will suit a series 2 rb25det motor.
looking for $1100 but will not seperate handcontroller and price is negotiable
contact me on 0401475561
cheers sam
https://www.sau.com.au/forums/topic/368168-series-2-rb25-power-fc-for-sale/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
