Ok so Im just about to purchase a new gizmo ms 2 boost controller, turbo timer etc
and was wondering if anyone out there could recommend a decent auto electrician in Newcastle to help with the install and actually install it properly?..
Thanks guys.. Joel
https://www.sau.com.au/forums/topic/368275-auto-electrician/
don't think he's willing to travel upto newy but give my mate a call and maybe you can come down sydney way and he'll be able to fit it all up for you
he's got a rb26 180sx so he knows his imports
pete 0407 008 651
Thanks for the info pig, much appreciated.. :) and I would do it myself Johnny if I was confident enough.. I'm pretty mechanically minded and do most of my modifications myself, but when it comes to electronics, I'm not so 'confident'.. So I just leave it to the experts.. Lol :P
No that's not normal, you should be able to leave your car unstarted for 3-4 weeks and still not have any trouble depending on what condition your battery is in?
Have you recently had any new devices installed in your car? Amps, cd players, etc etc?
As I said, I'm not too handy when it comes to electronics but sounds like you have a 'slow leak' somewhere so to speak..
nissan
naah it is the car, been through a few batteries now and same problem.
went out to someone off heres place in Edgecliff the other day and he went at it with a multimeter, me pulling out each fuse one by one.
found out that one of them (cant read the japanese to identify) is causing it to double in batt drain. its like 4 amps or something. So at least i saved this Pete guy a bit of time, forgot to ring him today, tomo for sure.
ta guys.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
