Hi all,
Just got my 'line in my garage after 4 long weeks waiting fro compliance, and well, i can't seem to find the tool kit which has the jack handle, wheel brace etc... Where did you guys find your one, there is a good chance I have missed out :D So if i have, anyone know where I could pick one up??
Cheers. :boobies2: :boobies2:
https://www.sau.com.au/forums/topic/36860-toolkit/
mine was next to my spare tyre.
in a black like pencil case, but had to buttons on it.
See if the compliers took em out mayb, Don't like compliers.. Dont trust em.
When i got my car back from compliers. I accelerated and a light fell out of it's light. They just placed it there.. Also i found later the fudged a h3 bulb into one of my headlights. Which does not even fit. My indicators on the side are so dodge aswell.
Might also try going 2 a jap wreckers, and seeing if bluebirds, or other cars from the era have got em. Or go 2 justjap myab, but the rip ya off i thinks.
https://www.sau.com.au/forums/topic/36860-toolkit/#findComment-736706
If its an r32, i found my jack, tyre iron and 2 yellow wheel chocks in the passenger side compartment in the boot.
If theyre not there, just buy a new jack from autobarn or whatever. Theyre all the same.
https://www.sau.com.au/forums/topic/36860-toolkit/#findComment-736764
I'm disappointed with your comments about Just Jap buddy. I and many other Forum uses have never ever found them to be a rip off and nothing ever short of helpful.
:kick: :kick: :kick: :kick: :kick:
Neil.
https://www.sau.com.au/forums/topic/36860-toolkit/#findComment-737159
Neil.
Sorry about that, just I remebr buying a s13 arieal there for $60 and it broke not long after and I had to bye another one @ $60.
Just thought was quite expensive for something that old.
Just Had a bad experince with them I guess.
https://www.sau.com.au/forums/topic/36860-toolkit/#findComment-738632
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
