At the end of the day, with clutches i think you get what you pay for.
don't pick the cheapest, mass produced clutch on the market because you'll find once your pushing 300+kw through it, its going to start to wear and have a short life.
you don't need to be a brand whore, but if you talk to genuine people in the business that know their stuff and arent just trying to make a sale. you'll soon find out what is good and what isnt.
simple little things like pivot point at which the clutch engages has a big effect on pedal feel.
i'd say you're going to be up for $1500-$2000 for a full clutch kit which will be reliable and hold a fair amount of power.
trust me, from my experience. do it right once, and not have to change or rebuild it every 12-18 months
if you're after a single plate, i reccomend talking to Jim Berry. but if you're dying for a twin plate. probably go for a Nismo
i went for single plate because it is cheaper to rebuild, whereas nismo can be costly for a rebuild kit.
but sometimes you never know how long a clutch will last. if the material is good and all your pads are even then it should last a long time. but if they aren't all equal width like mine were when i had it rebuilt by someone other than Jim Berry (not mentioning names) it didnt last and because of the uneven wear the engagement wasnt very good at all, it would slip because the load wasnt evenly spread over all pads.
Other than the power you're producing and the way you drive the thing, you also have to consider how much street use vs track use the car will get.
The only thing you've told us is that it's for a 34GTR.
Answer the above questions and the guys will be in a better position to properly reply.
Last thing we want on here is Andrew and Steve getting into a pissing competition :P
Andrews will go further he's taller ;)
I am the most bang for a buck guy you will meet. I have no experience with the NPC, but numerous examples of a certain other well advertised local clutch which just does not suit the applications it applies to. Trust me, spend once, spend less. You want to argue with 450+ rwkw on a mainline with slicks and semi slicks on the track, numerous 9000rpm launches, come see me, got the experience. When it comes to this, I don't even think of the clutch, simply, it works. Or you could spend half the money, at least twice, and worry about the clutch. Simple really. And yes, I am taller thumbsup.gif Steve you joker you action-smiley-069.gif
;) NPC's main clutch guy used to work at excedy he has run on the boards and doesn't talk rubbish either
i tell him the application and he tells me if he can build it
this is his HD skyline clutch
The pressure plate I use is a standard Exedy cover that is pulled down and fitted with the same diapghragm spring nismo uses in some of their pressure plates. I then modify the Exedy pressure
plate to suit a 5 puk sprung center disc that I make using a 4.2 ltr patrol clutch plate.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
