Big strong ones...
I've seen people with those "aircraft quality" t-bolt hose clamps, that look like they'll clamp your balls until they fall off. They're the ones I want.
Anyone know of somewhere in Sydney that sells them?
https://www.sau.com.au/forums/topic/36883-i-need-hose-clamps/
Blackwoods sell them in SS and mild steel (coated)
Enzed sell them in mild.
Personally I dont like the clamps I have got from above stores.
First off, they have a very small tolerance on size so you have to be accurate when buying. Not a huge problem but it means you have to bring in a sample of whatever you are planning on clamping to be sure you get it right.
I also dont like the way in which they clamp up. They tend to go egg shaped and bunch the hose up a bit when you do them up and it doesnt look to me like a nice solid, airtight connection.
They are also expensive although if you can get Blackwoods trade/account rates they are about half of regular retail prices. ie $10 ea vs $20 ea.
I would like to give the clamps shown at GCG's web site a go. They are slightly different in their design and I think they may work better.
Last time I was @ Pirtek in the gong they had some BITCHIN' hose clamps. Had the outside edges trailing up so they don't cut into the hose you're clamping and the part of the clamp that actually touched the hose was inside the main ring of the clamp. Sort of a clamp withini a clamp.
If you want the toughest ones available, I would suggest going to a diesel mechanic / diesel parts supplier.
Adrian
Thanks heaps for the replies guys...
I'm headed to Pirtek in Mascot (literally in Sydney Airport), so I'm hoping they have hose clamps that will suit me...
If not, I'll try the other options listed above... Those ones pictured from GCG don't look strong enough... I'm talking about the REAL big mother bitches, like an inch-wide metal band and big-ass bolt going through it :rofl::P :P
Merli, I have the ones you are talking about, and have no probs with the hose bunching. the only thing is you definately have to buy the right size, and the tolerance is a bit low - not much room to move.
I have seen some similar to the ones browny posted up, but they have heaps of washers between the nut on the bolt and the clamp - I have these too. they are better for tolerance, in that you can fit them to a wider range of hose sizes, and 'aparently' you can actually torque them down until you distort the pipe.
I do prefer the wider clamps myself, they also have a rolled edge so you know they wont cut into the silicone hoses.
cost here in SA from around $5-8 each ($8 being for the ones on my 3" pipework), that was from a speed shop, from an exhaust shop they were about $5 dearer each.
this is the best image I have at the moment, I could probably photoshop another when I get home (at work at the moment:)) - let me know?
The clamps on the BOV return are the heavy ones, I also run them from the turbo to the intercooler - the ones on the TB are the other type, with washers on the bolt. They work well too, but are thinner and dont have rolled edges.
The TB ones are available through autobarn (here in SA anyways) - they were fitted when I upgraded my IC to TB pipe, and I didnt have any of the heavier clamps on hand. Both seem to be handling 22+psi no probs.
THOSE ARE THE ONES I WANT!!!!
The ones on your BOV return pipe!!!
I'm off to Pirtek now, and if they don't have them, would it be possible for you to order me a bunch if I gave you the measurements of my silicone hosing? blowjob.gif
Should be able to work something out.
EDIT: you need to make sure the measurement is for the total diameter, including the silicone hose - they dont have a huge range of adjustment, about 5mm or so.
I will check with the local speed shop, as I am pretty sure he said he ordered them from east, see what I can find out for you.
More news, (one phone call later - big ups to Outlaw speed shop here in adeliade for all their help)
Try
High Performance World
1 Bourke st, Nth Parramatta
02 9630 2333
Outlaws said they should have them (they looked them up, as they are one of their suppliers), if not, ask if they know another speed shop in sydney
another name they suggested is Sydney Speed Shop.
If you have no luck with them, give me the dimensions and numbers of clamps you need, and I can go in and see outlaw speed shop here in adelaide and sort something this end.
I have the same clamps as 51jay
These pics show why I don't like them much.
As you tighten them up they tend to form a D shape
The "bunching" I was referring to
and the lack of contact around the bolt area
I have a few 86-91mm that I want to get rid of.
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
