Turbo sold as is, damaged rear bearing which took out the wheels
Includes drain, braided oil line, one water fitting.
Would suit someone who wants to re-core it with a garrett core so they can bolt on
but have higher flowing housings then stock.
No wastegate actuator
$250
https://www.sau.com.au/forums/topic/368839-rb2025-hks-2530-suit-new-core/
  • 3 weeks later...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
