Hey i have a couple of bits left over from my R34 im wrecking
RB25 NEO engine 98k on the clock comes complete with starters, air flow meters coils wiring
$1800 or $2000 with computer ono
17" wheels with great tyres as per picture $900 ono
Drivers side door in perfect condition with window $200 ono White in colour
Drivers side mirror $50 White in colour
Complete rear end with brakes will seperate brakes will be good for 5 stud conversion on silvia etc
Throw offers.
Still have spoiler white in colour good condition $100 ono bootlid is damaged on bottom.
Have the dashboard minus airbad in perfect condition $100
Triple gauges in centre of dash $75 ono
still have front and rear seats unfortunately all seats are series 2 except the passenger front one which has been replaced with a series 1 for some reason.
Throw offers
Have all interior panels in great condition including door trims rear side trims and verious other pieces. THROW OFFERS OUT THERE
Have a standard R200 viscous diff also
ALSO HAVE FRONT STRUT BRACE ! $100
May have other pieces just ask
LOCATED IN WINDSOR NEW SOUTH WALES
Tim
0404321025
https://www.sau.com.au/forums/topic/369105-r34-gtt-parts-and-wheels/
mate ur phone no. is not goin thru, i sent u a txt -from 0416424446 - i wanted to know the condition of the 3 front mud splashguards and the Z32, is it a real Z32 or cheap chinese one? where r u located in Windsor, can I come tomorrow after 230?
  • 1 year later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
