Hi guys im new to forum but wondering if someone could help me, i just done a full rebuild to my r32 gtst i put the engine in and all drove fine then i changed cross member but while changing my gbox fell of the jack and pulled driveshaft and engine down i dont know if this is what caused my problem but my car vibrates/ shakes reali bad when i rev it even when it is in neutral i have jacked it up and checked my engine mounts and my gbox cross member everything is tight and i have looked under the car for anything shaking while being i reved i saw nothing moving bad at all.
https://www.sau.com.au/forums/topic/369175-someone-plaese-help/
Well it's engine related by the sounds of it , just so we're straight , you were only changing the gearbox mount and not undo-ing anything else? , your engine mounts shouldn't cause it to vibrate even if they were broken , if i were you i'd be checking your harmonic balancer and other odds and ends around the front of the motor :unsure:
hey guys thanks for replying. i checked harmonic balancer all seems sweet but we figured out today that there is no rubber between my gbox and the gbox mount do you think this could be the problem it just seems likely because it only happened after i changed the cross member
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
