Hey guys for sale is my 1993 Nissan Skyline R33 GTS-T series 1, i believe its a special model as it has a GTR active LSD and ABS ( correct me if im wrong) :happy:
Also has Factory ABS, HICAS, Rear Strut Brace
I bought this initially when the engine in my GTR decided it had enough. And i needed a car to get around so i bought this.
But i never really ended up getting it registered, as i just drove my dads car instead.
The engine is completely stock apart from a blow off valve and a POD filter.
Has a HKS turbo timer
Clutch grabs nice and strong, i believe it to be heavy duty?
The exhaust has been removed as a mate wanted it
Stock wheels with good tread
It just needs a roadworthy and it can be registered, It has been complianced and registered before so no problems getting it registered.
Overall it is in okay condition, front bar has paint flaked off, little marks here and there, and paint on the roof has flaked off.
Contact number is 0432544363, text or calls are fine.
Im looking for $7000 negotiable
I'm just looking to get a straight cash sale as i just need some money to rebuild my engine! :laugh:
Located in Melbourne's western Suburbs (ST ALBANS)
Thanks for looking! if you need additional info or pics please message me!
Edited by RJ06
https://www.sau.com.au/forums/topic/369209-1993-r33-gts-t-manual-turbo-cheap/
I forgot to mention about the engine, gearbox ..
The cluster has 160k on it, not sure if the engine has been replaced or not, but it runs very smoothly, no problems at all!
Gear box is perfectly fine, shifts into every gear with ease, no grinding slipping etc...
Car is pretty much straight nothing to worry about.
Again im negotiable so if you are interested please give me a call text and we talk about it.
Cheers! :)
Its on eBay now for a quick sale!
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=220806015885
3 Day auction guys be quick!
Reasonable offers will not be refused, i need to sell it asap, will take $5000 if it is sold by thursday morning!!!!
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
