SPACERS...........
5x114.3
25mm $75
Wrecking R33 Skyline PARTs
Rear Calipers $80 Firm
Steering Rack $40
Stock Turbo
minimal shaft play
no actuator $250 Firm
Rb25det done 120xxx
And has had
NO modifications
( not even pod filter ) $1680 NEG
Rb25det Auto gearbox
Drove fine $300 NEG
R33 Tail lights
(tiny chip where indicator is) $70 PAIR comes with center garish
White Rear bar ( STD )
ill throw reo bar in $70
R33 white s2 Wing+boot $50 FOR BOTH!!
R33 Front Fenders $65 for left
Left one has a small paint $75 for right
chip where headlight is $120 for both
drivers side door skine
( GOOD NICK s2) $40
boot carpet $20
Rear seats $50
Oem Clutch ( looks like there
is alot left ) $80
Turbo Smart Bov Adapter (alloy) $18
s1 Centre Grill $18
S14 S2 PARTS
Hand Brake Set up
Lever plus cables $90
Brake booster and master
cylinder $90
Right hand door excluding
switch has some paint fade $90
Drivers door switch $35
S2 boot + wing
paint has faded $45
Auto Diff ( will fit man )
only done 130xxx minimel play $110
glove box ( good nick ) $30
Good nick Stock AFM $40
Ignition pack $40
Washer bottle ( no cracks ) $30
Mirrors Left And Right
tiny bit of paint fade
Black base red mirror $45 per side
S14 FULL rad support $60 CHEAP!!!!!!!
s13/180sx
Drivers Seat in ok condition(sr)$25
180sx Stock Rear bar (black) $25
180sx Stock ca front bar( Grey ) $25
Thats all i can think of right now
i have alot of photos so if you want to ask any questions or see anything just ask
[email protected]
0430106414
located in s.e suburbs Melb
willing to do swaps for r32 Gtr passenger / rear seats
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
