Hi, up for sale I have my 1998 Nissan R34 Skyline. See below for details.
Make/Model: Nissan R34 Skyline 25GT
Year: 1998
Kilometers: 130,000
Transmission type: Manual
Engine: RB25DE
Colour: Silver
Modifications:
Interior
Series 2 Cluster
Nismo Shift Knob
Kenwood Double-Din CD Player
Fusion 6" speakers all round
Drift Button
Exterior
Nismo Clear Side Indicators
Nismo Front Bar Indicators
Origin Bootlip
Origin Window Spoiler
Genuine Nissan Window Visors
Genuine Aero Kit (rear pods and sideskirts)
URAS copy front lip from Viva Garage (unfortunately this is fibreglass and I've already cracked it)
Suspension/Diff
Silk Road Section Spec RM/A8 Coilovers (10/8kg Spring Rate)
Neotech adjustable rear camber arms
Neotech adjustable rear traction arms
Adjustable rear toe arms
25mm Front Swaybar
24mm Rear Swaybar
Shimmed LSD
Rims/Tyres
Z33 350Z Rims (18x8 +30) which need tyres. I will include tyres for the 350Z rims if I get time to get a new set.
Plus a set of either S15 or R34 rims (buyer's choice).
Other
Aluminium Radiator
2.5" Exhaust with High Flow Cat
Mongoose M80S full alarm/immobiliser system
Asking Price: $13,000
Contact Details: Brent by phone (text or call anytime): 0448 058 670 or email: [email protected]
Other Comments: The body is in no means immaculate. The passenger guard and rear light are a slightly darker shade of silver and there are marks/dint around the car. An inspection would be advised.
The climate control for some reason will only blow air at cold or hot, no inbetween for some reason.
The ER34NA plates will be included in the sale.
I've had the car for almost two years now and has been great to me, however now off my P's I'm in search for a car which is turbo have purchased an R32 Turbo.
I have drifted this car at a few twilight events, and just recently up north in Coffs Harbour and performs really well..
If you have any questions at all don't hesitate to send me a PM, email or call/sms me.
Pictures:
With the full kit *Note: Car will be sold with 350Z Rims
*Note: Recaro and Nardi wheel will not be included in sale
How is sits with the 350Z rims
Doing skids
Edited by Brent
Price drop, $12,000. Also, rego is until December and the car has 137,000kms.
Need this gone as I've already purchased another car [R32 Turbo].
Edited by Brent
  • 1 month later...
Hey man, are you selling the 350z wheels on there own? if you are il take them.
Plus in the photo with the 350z wheels, have you got any body mods like skirts or rear bumper, or is it still stock?
If you havent got them separetly for sale its fine, but if you do end up selling them just let me know
Cheers.
Edited by R34 0125GT
Hi mate, sorry to gatecrash ur thread, but where did u get ur front lip from? If u'r parting the lip i would take it!! Cheers. Edit: just saw its from viva garage.. Anyways nice looking car!! Gl with the sale
Edited by myRB25DETT
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
