Hey guys parts left over from my 34GTT
Manual gearbox $1650 ono
RB25 NEO engine $1800 ono 98k on the clock
Coilovers i think there K-sport not leaking look alright $400
Front right gaurd $100
Right door complete $200
All door trims and side panels make offers cheap
Rear spoiler $95
Front and rear seats cheap make offers.
Anything else just ask guys car is white in colour
Located in WINDSOR NEW SOUTH WALES
Tim 0404321205
https://www.sau.com.au/forums/topic/369376-r34gtt-wrecking/
Do you have the fuel tank lid? The white plastic bit where the fuel hoses and electrical stuff runs through in to the tank.
Rear spoiler $95
Tim 0404321205
https://www.sau.com.au/forums/topic/369376-r34gtt-wrecking/#findComment-5888666
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
