Does anyone happen know how much current an R32 GTR pump draws @ full noise? Looked in the Nissan workshop manual but can't find a spec.
Thanks
Hi GTR32, easy question, not so simple answer. The current actually varies according to the fuel pressure. Of course the fuel pressure varies with the amount of boost.
So I have a little rule of thumb, that the electronics guru's will no doubt tell me is wrong, but it has worked for me so far. The standard GTR pumps is rated at 190 litres per hour, and I say that's about 190 watts of power. Divide that by 14 volts and you end up at 13.5 amps. Walbro rate their 190 litre per hour pump at 12.5 amps max current, so the "rule of thumb" is not too bad.
When we use a Bosch 044 rated at 330 litres per hour, divided by 14 = 24 amps. So I use a 30 amp fuse, relay and appropriately rated wiring.
Hope that helps
https://www.sau.com.au/forums/topic/36946-gtr-pump-amps/#findComment-738616
Hope that helps
If only the answers were simple. But then we wouldn't want to engage in the masochistic pastime of messing with cars would we? Heh heh.
How is the relationship between pressure and current established? I thought that (apart from the low voltage idle of Skyline pumps) once a pump was connected to 12v DC it ran at a constant rate, simply with less fuel returned as demand under boost and therefore pressure increased. Might have exposed my ignorance here!
Your rule of thumb seems to work pretty darn well, with some overhead for safety. Bosch rate the 044 @ 15.5 amps and the 'others' at 10.5.
https://www.sau.com.au/forums/topic/36946-gtr-pump-amps/#findComment-739446
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
