i got my new trust catch can but didnt come with brackets for mounting so i need somewhere that can either make brackets to spec or supply a small sheet of relativelly thick (prolly 8mm) aluminium, preferrably polished to match the catch can so i can mount it properly :)
any ideas of where to stick it ?
https://www.sau.com.au/forums/topic/36975-need-aluminium-to-make-brackets/
can't you just use one of them brackets that you use to hold pipes down... like gutter brackets n stuff. Failing that an aluminum ring clamp and rivet it to the inside of your car. Minimal fuss.
