1995 R33 GTS-T 5sp manual 2 door coupe White 93,000kms
*HKS Super Drager exhaust
*APEXI blow off valve
*APEXI turbo timer
*Dual stage Turbo smart boost control
*Autometer Boost gauge
*Dark tint
*17" AVS rims
*near new Falken tyres
*new brake pads
*KnN air filter
*KYB rear shock
*Kenwood player with 6 disc changer
*New Viper alarm with remote start
Regularly service and immaculate condition in and out.
Asking 22,500 neg. Please cal 0412902221 or email me at [email protected] if interested. Car is in Brisbane
Thanks.
https://www.sau.com.au/forums/topic/37012-1995-r33-gts-t-for-sale/
Please send some pics
[email protected]
*APEXI turbo timer
*Dark tint
*17" AVS rims
*new brake pads
*KnN air filter
*KYB rear shock
Thanks.
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
